Question about Pioneer Audio Players & Recorders
Axd 7532 manuals of remote control
Does anyone have a manual to know how to program pioneer remote axd 7247?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
May 22, 2016 | Pioneer Remote Control AXD7247 p/n:AXD7247
Why did my remote stop working?pioneer display axd 1479.do I have to buy a new one?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Mar 14, 2015 | Televison & Video
I need this remote to work on this system. Its an xv-htd540 surround sound system and i think the remote controll is an axd 7323 i dont know. If theirs a helpfull hint please let me know!! Thanks!
First you need to figure out the exact model number of the remote and also have you checked to see if they are compatible? That's all I'm gonna do if you give me the model number, second most remotes have a learn feature so if you still have the original remote you can "copy" the code of certain buttons to the remote you like to use. You provides very vague information. Is this remote original? I never tried to look up your remote because you put "I think" "I don't know" in your model number description and if you don't know I sure don't. Yes the models vary so I would need the right one. If it's not compatible and can't learn buttons the you would need to buy a new one unless the remote allows you to download codes. Good luck
Sep 07, 2014 | Audio Players & Recorders
Pioneer axd 1510
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
Universal remote controls are available at most of the electronic spare part selling shops.
Check this link too. http://remotesearch.blogspot.com/
Apr 18, 2014 | Televison & Video
Could anyone tell me what remote control part numbers would be compatible with my Pioneer receiver, model vsx 2014i? The AXD 7412, looks like mine did, but I'm not sure if it would work? Other mod
Visit this site for more details. Type in the site name Electro-help either to Google or Yahoo search box and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web.
May 15, 2012 | Pioneer Televison & Video
I just got a Pioneer SD-532HD5 and I thought it came with the original remote, apparently not. I have a Pioneer AXD-7430 remote and I cannot get it to work and menu type functions, only power channel and...
I would have thought a remote controller would have been included, tight shop!
The AX type won't work due to the wrong codes. A good quality "one for all" should do it.
Hope that helps.
Jan 25, 2011 | Televison & Video
Some buttons on the pioneer axd 7305 have to be pressed down realy hard to make them work
I know what is the errors, but I do not know how I shall arrange it. volymbuttons on my remote aint working not but if I move up some of the rubber buttons at the sensors the volume works . Perhaps it could be some magnetic on the rubberbottens or so..
Oct 10, 2009 | Televison & Video
Taylor 7532
I just changed the batteries today in min and it was a Litm. battery C2032
Dec 29, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
71 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
