Question about Air Tools & Compressors
Air compressor american forge pro 5hp 88142
Manual
4 Suggested Answers
  • 98 Answers
SOURCE: Inherited a Pro 4000 5HP 60 Gallon Air Compressor.
Heres a parts break down
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/devilbiss/RA5E60VAD_TYPE_1
for owners manual you can call Devilbiss and get one
Posted on Jul 22, 2009
dmftrucker
  • 1922 Answers
SOURCE: Wiring diagram to convert Craftsman 5HP Air compressor
look on the motor cover or on the wiring cvr on mtr or on the inside of the wire termination cvr
Posted on Oct 06, 2009
SOURCE: im looking for a replacement part for an american
don't have solution, but also need help/parts. I have American Forge Pro 5.5 HP upright air compressor (~8 years old). i can;t find any info on-line regarding. Was this air compressor made by another company and sold under american forge pro name? Only ID# on compressor is 88142 Can anyone help?
Posted on Jan 14, 2010
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
Pressure switch 120 volt compressor how to bypass pressure switch
Un-plug the compressor and remove the cover to the pressure switch. Inspect wire connections for burned /discolored wires. If not burned, look for button to manually trip switch (switch has on /off lever, place in on position). Test with ohm meter for continuity. Switch is normally closed and contacts are usually visable to evaluate condition. Some compressors use a very small sealed pressure switch that is also normally closed.
Oct 25, 2012 | Campbell Hausfeld 5HP 20 Gallon Single...
Looking for a product or instruction manual for a Mongomery Ward 2hp air compressor circa 1970's approx. Has the art.no. xer6468 and serial #12039-215993 printed on the side. This is a 2 cylinder oil...
If you need to tighten belt loosen the motor and slide back until belt taut and should have about 1/2" to 3/4" in deflection. You might try ebay for manual
Jul 29, 2017 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Im looking for a replacement part for an american forge air compressor need a manifold block that includes a regulator
Jan 12, 2010 | Rapid Air Tools & Compressors
I want to know , how much air ppresusser can it
they hold 150psi tops but i would set it to 100psi as this extends the compressor life
Sep 02, 2009 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
My husky pro vt631402aj verticle compressor won't stay running when compression rises
Hello,check to see if it cuts off at the same psi each time.If so,youneed to adjust the pressure switch to the tank to the max & adjust the pressure to the tool you want to run with the pressure out kob.Hope this helps
Dec 29, 2008 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Air Tools & Compressors Logo
221 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
