Question about Hitachi 50UX57B 50" Rear Projection Television
52" HITACHI PROJECTION ----50UX27KV6J009857
BLUE SHADOW, HOW DO I GET INTO THE CONVERGENCE ADJUSTMENT!!!!
  • zwamy Dec 02, 2007
    Is this an expensive repair?
    Problem Solver:
  • 12 Answers
Do you have a magic foucus button??
Posted on Aug 15, 2007
  • 398 Answers
If you mean that one of the colors has suddenly drooped toward the center, creating a curve along the side where the colors no longer line up, it means that one of your convergence IC's has burned out and needs to be replaced. You should not play with the convergence settings when this happens because when the IC is replaced, the settings will be all out and have to be reset. It is a good idea to replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's or realigned convergence circuits then allow a qualified tech to handle it for you.
Posted on Aug 07, 2007
I have a 50 inch projection tv we replaced the bulb on the left front of the tv and we still have a problem with a bright spot right in front of the tv, making it hard to view the tv. Is there a solution? Thanks for ur help alice
Posted on Dec 16, 2008
SOURCE:
Hatachi 42inch hd projection whole left side has shadow effect blue and red 3d images without 3d glasses
Thats a convergence failure and will require installing a convergence repair kit. You can get convergence repair kits for Hitachi models at www.tvrepairworld.com they come with the ICs low ohm resistors and the CD with repair instructions.
Jun 17, 2011 | Hitachi Televison & Video
Blue shadow hitachi 52"
No,ur tv have a problems known as a convergence problems,it dead.The tv convergence board must have it 2 STK convergence ICS and some or all it resistors must be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 16, 2010 | Hitachi 43GX01B 43" Rear Projection...
Rca rear projection screen way to much blue
replace convergence ics .press the menu and go into the convergence
alignment.see if you are able to align the blue convergence. if not replace the convergence ics.
Aug 04, 2009 | RCA P52771AT 52" Rear Projection...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 55inch projection tv with blue shadow.
Blue Convergence Ic is defective. let me know if you need to know where to get a replacement IC
May 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi ultrascan hd 42 in
The problem you are facing is a common problem in all rear projection TVs. It's called convergence. If you go into your menu there is an adjustment for it. if it doesn't move back into alignment then you have a more serious problem in the convergence circuit which will require replacement of components.
C-Dog
Feb 05, 2008 | Hitachi 43GX01B 43" Rear Projection...
Blue shadow
Needs convergence circuit repair = replace convergence IC's,
then activate Magic Focus...............need step by step?......T.
Nov 30, 2007 | Hitachi 43F300 43" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
729 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
