Question about Optics
Windage caps for V1393 bushnell rifle scope - Optics
  • 117 Answers
SOURCE: I have a Bushnell Sportview rifle scope wide angle
Try Midway at www.midwayusa.com.they have just about everything for anything in the shooting and optics world.Good Luck
Posted on Mar 25, 2009
  • 115 Answers
SOURCE: I have a Bushnell Sportview 3-7X20mm scope on a
most likely you will have to send the scope in to have this taken care of to contact bushnells customer service at 800-423-3537. press option 1. the age of the scope necessitates sending it in to have parts matched up.
Posted on Oct 06, 2009
  • 2418 Answers
SOURCE: rifle scope fogging
You can try to clear this your self. You will need a good sized clear plastic bag, say kitchen trashed can size. You will need to get your hands on some nitrogen or you can also use carbon dioxide. You will need some good electrical contact grease or Vaseline will also work. Take the focus lens off your scope, let it dry out. Now ck for any o-rings and try to find new if you can, put the grease on the screw threads.Put all the scope parts in the bag and pump up the bag with your nitrogen and tie off the bag but leave room so you can screw the lens back on once it has set for a little bit in the gas. This should let gas stay inside the scope so no moisture can get back inside to fog it up. Try that, sounds crazy but it will work.
Posted on Dec 05, 2009
  • 115 Answers
SOURCE: I need the windage dial for my Bushnell 3-9x38
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Posted on Mar 24, 2010
  • 12 Answers
SOURCE: how to zero Bushnell 3-9x40 scope rifle
http://www.bushnell.com/products/scopes/riflescopes/doa-riflescopes/
Go to this link & you will be able to zero it. If you lower the angle of telescope you will be targetting farther. vice versa. aqeelhafeez@hotmail.com
Posted on Mar 26, 2010
Exploded diagram
You don't actually adjust cross hairs, you adjust point of impact. You do this using the turrets located near the center of the scope. the top one will adjust height, the r hand one will adjust windage.
Feb 21, 2014 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
How to disassemble my bushnell sportsman rifle scopes coz i wnt to clean it
On my Bushnell scope I have an adjustable angle ring that will bring in the view, it is held in place with 1 screw. remove it and pull down towards the windage and elevation adjustment screws. There are 3 tiny phillips screws, remove them. Then unscrew the end of the Eye Peice end peice with the lens in it. inside on the outer edge of the main tube there is a locking ring that keeps the eye peice from unscrewing off, remove it and unscrew the entire eye peice. you are now ready remove the inner tube. Be careful here this is where you can damage the cross hairs and lose the leaf spring that maintains pressure against the windage and elevation screws. When you reassemble after cleaning and with the elevation screw at 12 o'clock and windage screw at 3 o;colck, the leaf spring will be in the 7 or 8 O"clock position, it just sits in there up against a little ridge inside, with the bow facing to the center. Back off the elevation and windage screws all the way so they don't block the inner tube from going in all the way. Once it is in adjust it so the cross hairs are orented correctly and put it back together. If you want to refill with Nitrogen remove the front lense and take to someone that fills tires with Nitrogen and inject the nitrogen into the scope, Quickly reinstall the front lens as nitrogen is about 3% lighter than air and if you take too long it will all escape.
This worked well for me. Good Luck and Happy shooting
Apr 27, 2011 | Bushnell Sportsman 4x32 Riflescope (4x32...
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
Cannot get to the bull's eye. rifle shoots 2" to right of bull's eye. after two full turns left on windage - nothing happened. I',m ready to return to the store. Any help???
continue to adjust the wind-age. If your problem persists I would suggest turning both to a random point and re-start sighting the gun. If that does not fix the problem return the sight because this most likely means the wind-age is disconnected.
Aug 17, 2010 | Bushnell .22 Rimfire 3-9x32 Rifle Scope...
What are the adjustment knobs on the windage position for? Is it to adjust sighting or to focus the scope? Why are they not covered like most scopes are
The adj knobs on there are for windage on the right and elevation on the top, if they are not covered, they are turret knobs for target shooting, not for hunting. The focus knob is the rear lens, it spins in and out to fit your eyesight. It usually focus on the crosshairs and the distance for most shooters, some will not be able to get it right because of their eyes. 98% will. Hope this helps.
Jul 31, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I need the windage dial for my Bushnell 3-9x38 Sportview Rifle Scope 74-3938. The adjustment wheel is frozen.
Mar 23, 2010 | Bushnell 3-9x38 Sportview Rifle Scope...
Bausch & Lomb Balvar 6x24 Rifle target scope
Bushnell owns baush&lomb scope I have called them to repair my elite series bausch&lomb and I have been very happy with there customer service.They might be able to help with your problem to.
Mar 01, 2010 | Bausch and Lomb Bausch & Lomb Hunting...
Sight adjustments
It's a common misconception that you are moving the bullet's impact on the target... the bullet is hitting where the rifle is pointing and you want to get the scope to look at that very same spot.
To move the scope's reticle up or down, turn the elevation adjustment on the TOP of the scope in the direction you want the scope to look, so if your shooting low, turn the scope's adjustment in the DOWN direction.
If you want to move the direction the scope is looking left or right, turn the windage adjustment on the RIGHT side of the scope left or right to look where the bullet is impacting. To move the crosshairs to the right, turn it right.
Hope this helps, Mark the Gunsmith
Dec 11, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
Lost caps
I'm not sure how this got posted in the car audio section...
If the scope was manufactured by a well established company, you should be able to get a new cap from them.
If you cannot locate the manufacturer, you can move the other cap to the windage adjustment to set the windage. Then when you're finished, move the cap back to the elevation adjustment.
Even if you use it for a shooting discipline that requires constant adjustment, it's unlikely that you'll need to use the windage adjustment for anything other than setting the zero.
Oct 16, 2007 | Hifonics Titan TX 8805 Multi-Channel Amp...
Optics Logo
Top Optics Experts
james laughton
james laughton
ray gallant
Are you an Optic Expert? Answer questions, earn points and help others
