Question about Crocs Croc Infared Flat Iron 1"
Error message i was using my flat iron and when i finish I pluged of. When I wanted to use it again it say error
3 Suggested Answers
SOURCE: My croc flat iron goes
It's not working! I've tried unplugging it for a minute, plugging it back in and holding the power button on....am i missing something. I've had this damn thing for about 2 months. Please dont tell me i have to buy another one....AAAHHHHH!
Posted on Jun 11, 2012
Had my croc iron for one month and now it only heats up to 69 and the gives an err message.. Is there anything that can be done to fix this?
Posted on Jan 20, 2013
How do i descale a team international steam pro 2600w iron
Buy a bottle of descaler and put it in the tank where you normally put the water. Put iron on hottest steam poison and run steam , topping up as required. Rinse thoroughly when finished and iron has cooled. Use distilled or demineralised water for steaming and the iron shouldn't require cleaning again.
Dec 02, 2014 | Irons
Tip
How to avoid damage your hair when using a hair straightener
1. Choose a hair flat iron depend on your hair type
The plate of a flat iron can be made by different material, while some materials will straight hair in a single pass, others might require more effort. So, before you go out and buy a straightener, you need to know which plate material suits your needs.
2. Go for Adjustable temperature Controls
No matter what type of material an iron has, it can malfunction. So, always invest your money in a straightener which has low, medium and high temperature settings. Afterward, to give your hair your favorite styles, try to keep the heat as low as possible.
3. Choose Size wisely
If you have short hair, you might want to go for a smaller iron. Conversely, only if you have extremely thick hair than going for a larger iron.
4. Fully Dry Your Hair
Unless you are using a wet iron, it's imperatively you fully dry your hair before ironing them. For, if you have wet hair while ironing, boiling the moisture out of them might do serious damage.
5. Use a heat protectant
Better be safe than be sorry. You don't want your hair to lose too much moisture while ironing. So, you might want to apply a heat protectant which will retain moisture in the face of excessive heat.
6. Don't heat one section for too long
While ironing hair, it is best that you divide them into different parts. Afterward, straighten each part for a specific time period which shouldn't be too long. For example, if you are using a flat or curling iron, it is essential that you never heat a single section of air with it for more than 5 seconds.
Source : http://selectedo.com/best-hair-flat-irons/
on Sep 29, 2017 | Health & Beauty
How to Reset a Croc Infared Flat Iron 1
Mine does that too! And I don't know what to do!
Jun 07, 2012 | Crocs Croc Infared Flat Iron 1"
My croc flat iron goes to 69 than shows error message
May 28, 2011 | Crocs Croc Classic Flat Iron Titanium...
Dri have 26 inch flat screen tv and what the problem is that it will just shut off and it will take a day or to power up even the red ligt to let u no that its pluged in dosent even light up but leaving it...
its easy fix if you can use a soldering iron.....
needs new caops on the power supply board.........
if you cant use s/i ...
obtain replacement p/s/b from ebay..........
cheers
Apr 11, 2011 | Element Electronics Televison & Video
How to empty water form iron when finished
Unless you are not going to use the iron for a long time, especially if you use distilled water to fill your steam iron, I would really not bother.
However, if you do want to empty the iron after using it, you have a couple options:
- With the iron still hot, very carefully, use the cleaning function or the 'shot' of steam until no more steam is generated above the sink preferrably.
- With the iron unplug/NO electricty: very carefully tip the water out from whe filling hole above the sink - be aware that the water will remain extremely hot for a long time so avoid splashing water on yourrsel!
Hope the information is useful.
Sep 23, 2010 | Black & Decker D2030 Iron
Pc Game Error
Hi! I'm trying to install My Horse and Me the PC game, the installation goes through everything normal and but when I press Finish it gives me this error message
Unhandled Exception
Error Number:0x80040702
Description:Failed to load DLL:GameuxInstallHelper
When I press OK the installation window where you press Finish pops back up and it says
InstallShield Wizard Complete
The wizard was interrupted before MyHorseAndMe could be completely installed.
The system has not been modified.To install this program at a later time,run the installation again.
Click Finish to exit the wizard.
So I press Finish and then if I try to go and find it its not there its been uninstalled. And I have tried installing it several times with no luck .
So if you could please help me that would be wonderful because I really want to play my game.
Thank You!
Nov 14, 2009 | Atari Video Game Consoles & Games
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
Jan 13, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Crocs Croc Infared Flat Iron 1" Logo
Top Crocs Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Crocs Health and Beauty Expert? Answer questions, earn points and help others
