Question about Husqvarna 3300 PSI 3.2 GPM Gas Pressure Washer 020524
How to change the pump oil at - Husqvarna 3300 PSI 3.2 GPM Gas Pressure Washer 020524
How change oil pump of 2000 Chrysler Concorde
Chrysler Concorde oil pump Questions & Answers - Fixya
www.fixya.com > Forum > Tags > oil pump > Cars & Trucks > Chrysler
Ask your Chrysler oil pump related question. ... oil pump in 1999 chrysler concordehow do you change the oil pump in a 1999 ... Question about 2000 Concorde.
Aug 30, 2015 | Chrysler Cars & Trucks
Why the oil light came on and off, I had change the new pump,pick up screen, and change the oil sending unit ?
Most likely the oil pump light will come on if the oil pressure is low. This light is based on a pressure sensor. Your oil pump is likely not operating to deliver the required pressure. Check that your pump is installed properly.
Feb 01, 2015 | 2005 Dodge Durango
No oil pressure, ticking motor
Possibly a failed oil pump. Check engine oil level first.Make sure it is at least to the safe zone on your engine dipstick. if the motor has not had regular oil changes ( i change mine every 3000 miles like clock work) the oil can sludge and clog oil passages and pickup screen to oil pump.
Jul 19, 2014 | 1998 Dodge Durango
How to change oil pump
Changing the oil pump is not easy, the oil pump is situated in the engine oil sump. So you have to go under the car and remove the oil sump pan to get at it. First you have to drain the oil. I recommend you buy a repair manual such as Haynes from a auto parts shop for about $15 before you start the job and follow the instructions in the manual. Good luck
Jun 25, 2014 | 1999 Dodge Durango
We have a robinair cooltech 34700z, looking for directions to change pump oil, can anyone help? thanks
For change vacuum pump oil follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL" then press "YES" key. Now vacuum pump will run for two minute & stop automatically. When pump stop you just open the oil drain cap and drain all used oil from pump (oil drain cap located outside of the machine near high & low side hose). After draining all used oil replace oil drain cap and fill 5 ounce new ROBINAIR vacuum pump oil then press "YES" key and keep filling oil up to middle of sight glass of vacuum pump. Press "STOP" key to complete the process.
NOTE: Do not over fill the pump & do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support
Hope this will help you. If so please vote for it. Good luck
Apr 08, 2011 | Robinair Cool Tech 34700Z Recovery,...
Low oil pressure warning light comes on. oil level is ok
four theories.. two easy.. two not so easy.
one. oil filter is plugged.- change the filter
two. the pick up screen in the oil pan is clogged.- remove oil pan(if you go this far change the oil pump on speculation)
three. the oil pump itself is worn out of tolerance.- remove oil pan, change pump
four. the sensor is defective- change the sensor on side of engine.
Dec 31, 2010 | 2004 Ford Taurus
I have a robinair 34700zasking me if i wanna change the oil nowhow do i do that and what type of oil i need to use?....ty
You have run the machine 10+ hours for vacuum since last oil change. so you have to change vacuum pump oil. For change vacuum pump oil just follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL'' then press "YES" key. Now vacuum pmp will run for two minute & stop automaticly. When pump stop you just open the oil drain plug & oil fill cap of vacuum pump ( Located oute side of the machine near high & low side hose ) & drain all oil from vacuum pump. After draining used oil,replace oil drain plug & fill new ROBINAIR vacuum pump oil till middel of sight glass.Press "YES" key & follow on screen messeage. NOTE: Do not over fill the pump & Do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support.
Jul 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
How are is it to replace the oil pump. just
Yes it can, do an oil change and filter. If oil isn't changed at regular intervals, the filter can become clogged and won't get a good flow.
It's best to change the oil every 3 months or 3,000 miles, whichever comes first.
Changing the pump is not an easy job.
Nov 20, 2009 | 1993 Buick Park Avenue
Have dye in vacuum pump oil on cooltech 34700z also a buzzing noise
You have to change vacuum pump oil.By pressing "change vacuum pump oil" follow the on scree messege & compleat process. NOTE:please do not skip any option during oil change & do not over fille the pump.
Oct 19, 2009 | Robinair Cool Tech 34700Z Recovery,...
Husqvarna 3300 PSI 3.2 GPM Gas Pressure Washer 020524 Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
