Question about Frigidaire GL38LKEC (LP) Grill
Grill burner replacement - Frigidaire GL38LKEC (LP) Grill
I am in the process of replacing my burners on a Jenn Air model #7200063LP. The burners appear to slide into the gas feed tube on the front part of the grill and attached to the back part of the grill with...
Yes, there really is enough space. Remove the cotter pin(s) and while lifting up the end of the burner farthest from you, pull the burner up and out.
To replace the burners, do the above in reverse. Just be sure the burner tube slides over the burner orifice, properly.
Hope this helped you change the burners and Happy Grilling!!
Jun 06, 2011 | Jenn-Air Grilling
How do I light the grill manually
Get a butane grill lighter. Open the hood of your grill. Remove the cooking grates and one by one turn the burner to low. Light the butane grill lighter prior to turning the burner on and as you turn the burner to low touch the flame of the lighter to the burner. Leave all burners on low, until you replace the cooking grates. Be very very careful, as you don't want gas to buildup before each burner is lit.
Then contact Brinkman for replacement ignitors.
Jan 30, 2011 | Brinkmann ProSeries 810-6330-W Grill
Looking for replacement parts for SPG90B Campcheif Big Gas 3
I looked around online and could not find anything for my gas grill. My burners all disentergrated. I found Walmart is a good source for cheap generic grill parts but only at certain times of the year. I recently replaced 3 burners on my gas grill. The new burners were build like a trombone so one size fits any grill. The metal looks a lot better than the original equipment. At $10 a burner I am back in action!
Sep 29, 2010 | Camp Chef Big Gass III - SPG-90B Grill
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
3 burner charmglow gas gril
I am replacing burners and I need to know if the burners if they go tightened or loose.
Oct 20, 2009 | Brinkmann Charmglow Stainless Steel LP...
I need 3 burners for Grand Gourmet Gas Grill Model No. GBC621A-M
Try this link: http://www.grillstuff.com/grill-parts/brinkmann/810-2300-b/?cat=27&brand=5&model=8938
It should bring you right to your specific grill and list replacement parts including burners.
Cheers!
Sep 08, 2009 | Brinkmann 810-2300-B Grill
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Expensive TEC Grill Problem with Blowout After Ignition
HI nabber8391,
I have a TEC Pattio II. I have owned the grill for almost 10 years and TEC grills have a ten year warranty on many of the parts including the burners. The burners on my grill have a ceramic inserts. The pop and loud whooshing noises indicate the ceramic insert or the seal on the burner is "cracked". I have replaced both of the inserts and burners on my grill once about 5 years ago under warranty. I have one burner now that will not stay burning and I contacted TEC today regarding the problem, and I will replace the ceramic insert only under warranty. .
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom.
YOUR ONLY OPTION IS TO CONTACT THE CUSTOMER SERVICE GROUP AT TEC. THE TELEPHONE NUMBER IS 1-800-331-0097. TEC IS LOCATED IN COLUMBIA SC. TEC HAS A USEFUL WEBSITE.
By the way, I paid $1400 for my TEC grill in 1999, but I believe the new TEC grills are better. I know I would not buy any other brand. One other thought, it is imperative that cleaning instructions are followed.
Jun 23, 2008 | Tec RadiantWave Grill
Sputtering grill
The newest TEC grills like yours have the TEC Radiant Glass Infra-red Cooking System with stainless steel burners with glass surfaces. I assumed this burner system had eliminated the problem of the burners going out with a loud boom or sputtering.
May 01, 2008 | Tec RadiantWave Grill
Frigidaire GL38LKEC (LP) Grill Logo
44 people viewed this question
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
