Question about Microwave Ovens
Kenmore oven 316065304
Where does the oven vent? If from top left of stove, the paint is peeling from under the display.
MicrowaveSvc
  • 9047 Answers
SOURCE: peeling paint
You need to thoroughly clean it, then sand it smooth to removew all the loose paint.
Once it's squeaky clean and dry, you can apply high-temperature appliance paint, which is available in brush-on or spray-on form at big box stores like Wal-Mart, home improvement centers like Lowe's and appliance parts stores.
Posted on Nov 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing, which can be messy.
Posted on Nov 23, 2008
  • 4 Answers
SOURCE: PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Posted on Apr 03, 2009
SUPERMAN_B_1
  • 294 Answers
SOURCE: paint coming off inside microwave oven
HELLO' WITH IT BEING INSIDE A MICROWAVE I'LD ALSO BE WORRIED ABOUT RADIATION POISON SOUNDS LIKE ITS TIME FOR A NEW MICROWAVE
Posted on Apr 05, 2009
EwingElect
  • 276 Answers
SOURCE: The paint in the cavity of my 6 year old microwave
Sand off the loose paint and make sure that there are no holes in the cavity. If there's holes the unit is not safe to use.
If it's just surface flaking, it should be safe to sand back with fine grade wet/dry sandpaper. We usually respray with automotive paint in a colour close to the cavity colour.
Posted on May 27, 2010
Testimonial: "thanks!"
Danby microwave ovens
Yes it is a certain danger, DO NOT USE your microwave until this has been repaired. You should be able to get specialist paint and kit from your local hardware store. Here's a handy kit I found online:
Microwave Oven painted lining repair kit MSC TOUCHUPKIT
Mar 20, 2014 | Danby Microwave Ovens
Inside of microwave top peeling and blistering
If it's paint peeling, then once that paint is gone, rust will set in, which can cause arcing and disintegration of the chassis, when ruins the oven.
This peeling is usually the result of excess moisture accumulating in the oven due to blocked air vents or poor fan circulation.
Once those two issues have been ruled out or dealt with, then always be sure to dry out or leave the microwave open after use.
The peeling paint will need to be removed, then the area should be sanded.
We're
Nov 28, 2011 | Morphy Richards AM925EF Microwave Oven
I Bought An Old Kenmore Space Saver Microwave. It Doesnt Have A Manual. I Dont Know If It Can Go Over Top Of Electric Range Stove. I Dont know How To Install It. So What Im Asking Is How Can I Tell If It...
One quick way would be to look on the top of the unit. Do you see empty screw holes where the screws going through the cabinet above it will go through and screw into the top of that unit? If no open screw holes on top of unit probably not an over the range model. Also, look under the bottom of the machine. do you see feet??? Or just aluminum screen vent filters. If feet and no filters probably a counter top unit.
Sep 18, 2017 | Kenmore 62702 Microwave Oven
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Kenmore microwave inside chipping, is this a
Only your microwave's health. *grin* Seriously, it can begin arcing and damage the oven, possibly ruining it.
You'll need to strip the old paint away, sand the area smooth, then clean and dry it thoroughly.
Then you can apply high temperature appliance paint available at hardware stores, home centers, and places like Wal-Mart.
After that, be sure to avoid spills and wipe out the oven any time there is heavy steam.
Dec 27, 2009 | Sharp R-820B Convection/Microwave Oven
The paint has started to peel off inside my microwave!
NO. The insides are baked on powder coat. If you paint it, you might as well throw it away. The paint can catch fire, even after it is dry.
Aug 07, 2009 | Electrolux Microwave Ovens
I have a Kenmore microwave oven and the paint under the turntable is peeling. Is this harmful? Is there a fix or paint that I can use to correct the unsightliness of it?
You should re-paint it using microwave touch-up paint.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 14, 2009 | Kenmore 62702 Microwave Oven
Inside finish is peeling off
Nov 21, 2008 | Microwave Ovens
Model Number JE2160SF03 Serial Number: DL 901299M Our microwave oven's floor is peeling off horridly. We can see the metal beneath the white surface. We have lived here for two years, and it was a brand...
This is usually due to spills, inadequate ventilation, or cooking on the stove top without having the hood / vent fan on.
It really should be sanded smooth and clean and dried thoroughly.
Aug 13, 2008 | GE Microwave Ovens
Peeling paint
Here is a link to buy the paint.
If the microwave is not creating a spark inside when in use, It's OK to use.
Mar 09, 2008 | Rival MT660 Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
