Question about Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue
Strider midi 4
Groene led knippert fout indicatie hoe krijg ik hem loopend dat hij weer werkt
3 Suggested Answers
  • 17 Answers
SOURCE: the brushes in the electric motor of my strider midi 4 plus mobil
This could be caused by the commutator not being smooth and causing undo where on the brushes
Posted on Jun 06, 2010
wcdoc1953
  • 280 Answers
SOURCE: I have a strider midi 4 plus mobility scooter and
You should be able to find a local shop that specializes in rebuilding DC motors. The cost of a rebuilt motor is considerably less than a new one. The rebuild shop will turn the armature, replace the brushes, replace the armature bearings, clean up and replace the contacts, etc. The only downside is that the warranty will only be upwards of 90 days. In my experience a rebuilt motor may get you an additional 6 to 8 months before it needs to be replaced with a new one. You need to weigh the cost of each alternative and make a decision. If you have a free source of labor, the choice becomes easier.
Unfortunately, I cannot recommend any rebuild resources since I live in the U.S. Hope this helps.
Posted on Feb 06, 2011
Wanneer ik herstelschijven in pc steek krijg ik na een tijdje de foutmelding fout 0x4001100200001005.is er iemand die mij kan helpen
I'm sorry I cant speak dutch. Use this if cant follow english too well. https://translate.google.com/#nl/en/
I got this from an hp support forum:
"you get a 0x400 error is because the OEM hard drive was replaced with a retail hard drive. OEM drives are "tattooed" or branded.. and the recovery media will search for it before installing. Prevents the spread (aka pirating) of OEM recovery media to computers that it did not ship with."
Look under the laptop to find out which version of windows you have.
get a COPY of that operating system and install it. Activate the operating system with the product key which you will again find under the laptop.
Jul 16, 2014 | HP Pavilion Computers & Internet
Ik kan soms wegpagina niet openen en krijg als fout : "LSP (Layered service provider) werkt niet juist. Hoe is dat op te lossen? Dank bij voorbaat
Herstellen naar een vroeg stadium en het scannen en verwijderen van virussen met een goede virusscanner en werk vervolgens de LSP uit Micrososft.com
Jun 29, 2011 | Microsoft Windows Vista Home Premium with...
Mijn vraag is, dat ik een jumbo universal remote controler heb gekocht maar deze niet kan laten functioneren, ik zou dus willen weten hoe je hem kunt installeren op betreffende apparaten? Ronald.
Normaal zouden instructies meegeleverd zijn.
Ik neem aan dat het om de grote zilveren afstandsbediening gaat ?
1- zet het apparaat wat je wilt bedienen aan
2- druk de knop "code search" ongeveer 3 seconden in tot het lampje blijft branden.
3- druk op de knop tv/dvd afhalkelijk voor welk apparaat je programeert (led knippert en blijft aan)
4- recht de afstandsbediening naar het te programeren en druk met korte pauzes op de stand-by knop tot het apparaat zich uitschakelt (het led knippert bij indrukken telkens een keer)
5- waneer het apparaat uitschakelt is de code gevonden en dient deze worden vastgelegd door op de knop "enter" te drukken (led schakelt uit)
engelse instructies staan hier
Dec 25, 2010 | Universal Remote Control Remote Control
Hoe reset IK EEN W210 bj 1997. Ik bedoel als hij aangeeft dat je de service overschreden hebt
DE GARAGE IS TE VERONDERSTELLEN KIJK JE AUTO UITSTOOT EN DOE EEN DIAGNOSTIC CHECK.MAKE ERVOOR DAT ALLES GOED WERKT CONDITIONS.THE GARAGE HEEFT OM UIT TE SCHAKELEN SERVICE ONDERHOUD LICHT.
May 12, 2010 | 1994 Mercedes-Benz C-Class
Microsoft office outlook werkt niet meer
Try creating a new profile through the Control Panel and set that as the default profile to be used in Outlook.
Dec 21, 2009 | Microsoft Office Professional Edition 2003...
Als ik mn compaq r3000 opstart......
Je r3000 kan de harde schijf niet meer vinden, iets te hard laten stuiteren? ff harddisk losdraaien en er weer induwen (zit met een zwart klepje met 2 schroeven vast onderop). Anders een windows cd erin, opstarten, en kijken of die een harde schijf kan zien, want er kan ook wel gewoon data corrupt zijn. Ziet de windows-cd de harde schijf wel, dan setup doen, windows zal de oude vinden en reparatie voorstellen. Mits je dezelfde versie hebt van windows natuurlijk.
Feb 15, 2009 | Compaq Presario R3000 Notebook
Fax verzenden
Kijk eens in de instellingen via je browser. ga naa het ip adres van je printer en je kan alle instellingen gemakkelijk bekijken en wijzigen.
Jan 29, 2009 | Dell 1815dn All-In-One Laser Printer
Bij aanvang van printen of kopi?ren stopt hij en de spanning valt
hoi , ik denk ook dat dat je printer kapot is want als alles gewoon werkt maar het wil niet printen dat kan niet goed zijn ik hoop dat je garantie er op hebt dan gewoon terug brengen en laten repareren
Jan 03, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue Logo
21 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
