Question about LG Washing Machines
Washing machine water hammer - LG Washing Machines
2 Suggested Answers
  • 569 Answers
SOURCE: maytag neptune causing water hammer what part is bad?
Fit a water hammer arrestor in the feed pipe as close as is convenient to the appliance.
http://www.masefield-epson.co.uk/plumbing-products/20/21.html
Posted on Jan 10, 2010
How to stop water hammer
Connect hose-to-galvanized pipe adapter to shut off valve at washing machine.
Install galvanized 45 or 90 and then attach vertical 18" pipe with cap.
Then install galvanized-to-hose adapter and connect washing machine hose.
Crude illustration:
http://waterheatertimer.org/images/Add-air-chamber-1.jpg
Gene
h
Dec 04, 2013 | Water Heaters
How to get rid of water pipe noise at home
This usually occurs with high water pressures.
It may help by installing a water reducing valve at the water meter.
When a dish washer or washing machine turns on and off the water you will get a water hammer noise. The pipe fixings have come loose over time and the pipe bangs against the fixings.
You can reduce this noise by installing a water hammer device on the all the taps and then connecting the hoses from the dishwasher and washing machines to the water hammer devices.
I suggest you check out the best options with a plumber.
Apr 04, 2013 | Dane-Elec DaneElec 4GB USB Drive Copper...
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
The flow of the cold water seems to be restricted. The hot water pores into the tub. The cold trickles in. After disconnecting the cold hose, hot water back feeds out of the cold input side of the machine....
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 16, 2010 | Washing Machines
With water hammer arrestors in place, there is
The water hammer arrester installed at the washer is not large enough to suppress the water hammer you are experiencing. This could be due to the length of the pipe between the washer and the water heater or the number of turns in the pipe. Water hammer can occur at right angle turns. Install another arrester near the water heater or at a turn where you hear the hammer sound occur.
Nov 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer's hot water valve has water hammer
loose spring within valve..Fit new solonoid valve...You could try reducing water pressure slightly
Oct 06, 2009 | Washing Machines
Washer bangs between wash cycle and first spin/rinse cyle
Sounds like you need a water hammer control in your Hot water line, usually it's teed into the line and is just a short length of pipe with a cap on it, acts like a shock absorber
Aug 22, 2009 | Kenmore 46462 Front Load Washer
We replaced our old wash machine with a front loading LG Steam Washer 2487. When the machine initially fills, it sucks water in short, sharp bursts, which is making our pipe bang loudly. Short of cutting...
This is called water hammer - and is caused from AIR in your pipes.
There are Hammer Arrestors made to eliminate (or lessen) the hammering.
You should also bleed the air from the pipes - and re-prime them.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 01, 2009 | Washing Machines
Washing machine
The hot/cold water fill solenoid might be stuck open.  Try banging on it lightly with a hammer and if that doesn't loosen it, replace it.
Oct 09, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Washing Machines Logo
18 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
