Question about Ken Tech Large Digital Atomic Clock T4668
Ken tech clock instructions
Need to know how to turn off alarm
Valet 562t remote was in valet made & doors would only lock & unlock & now when i was trying to get out of valet mode it flashes lights but nothing more now. What could be my problem?
need to get the owners manual and follow the programing . cause what you are doing at this point is programing the alarm . basicly you are turn on and off features of the alarm try to function the valet switch.. and hitting the remote lock and unlock buttons . on some alarms you flip the valet switch and press lock or unlock button on the remote and listen for a certain number of chirps from the alarm to know what you turning on and off . that is why you need the manual so you know what feature of the alarm the number of chips is turning on or off when you hear them
radiorepair@windowtintingin239.com
Oct 29, 2013 | Car Audio & Video
Need instructions for Discovery Kids Projection Daisy Bloom Alarm Clock
1.set time: hold down "clock" button for five seconds, then use up and down arrows to change, and press "clock" button once to toggle between month/day/year/hour/minute. Try it a few times b/c sometimes it just goes to the alarm setting (i don't know why, i think it's a glitch).
2.set alarm: hold down "alarm" button for 5 seconds, use up and down arrows to change, press "alarm" button once to toggle between hour/minute. press "clock" button to return to clock
3.turn on/off alarm: press "alarm" button once, press up to turn alarm on and press up again to turn alarm off. press "clock" button to return to clock
4.to project the images: push the buttons that look like video cameras. to focus the image, rotate the cylinder around the lens that projects the image. on the daisy clock, there's a button on top that you can use to flip the projected image of the time upside down. use the dial next to the lens-cylinders to select a different image (you may need to point the cylinders in a different direction to reach the dial)
Aug 19, 2013 | Bon-Ton Kids Discovery Kids Projection...
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 | Watches
Need manual for iCraig CMB3228. Can not reset clock or alarms.
with the power off press and hold the vol+/alm1 until the hour is blinking then change, press the vol+/alm 1 again to change the mins. same thing for the alarm 2. make sure the PM light is lit up if it an afternoon alarm.
what I need to know is How to turn off the alarm completely?
Nov 24, 2012 | Craig iDual Alarm Clock, Digital PLL FM...
Have a bluehat time space projection alarm clock and the alarm won't turn off. Always goes to a snooze mode. Need help making it turn off. Instruction Manuel offers no help.
To turn off the alarm I pressed the alarm set button. While in the alarm set mode press the up button to turn the alarm and snooze off and on. That's what worked for us. Neat clock, the instructions are just a little lacking:)
Jan 19, 2012 | Toys
Alarm set
this is a factory alarm, the problem is the alarm is active, you will need to use the door locks to turn alarm off, insert key in driversdoor and lock and then unlock door this will turn alarm off, if that doesnt work then use pass/side door, the lock has a built in switch that knows when the door is locked or opened, the driversdoor may have a bad switch so inturn the computer thinks the door was forced opened without key and it is turning alarm on, so again use the key to unlock door try the pass/side if driversdoor doesnt work. good day
Nov 24, 2011 | 1998 Plymouth Voyager
1997 dodge stratus agency alarm came on now car seems to be blocked it turns on but then turns off and the alarm keeps honking when i turn the ing switch to on position the lights,door locks,stereo and...
You need to get the alarm system reprogrammed. I don't know your personal code. It may be in the owner manual. If not, you will need to call a Dodge dealer.
Feb 15, 2011 | 1997 Dodge Stratus
How do I turn off my car alarm
Is it a factory alarm? If not, we need to know the make and model of the alarm.
Feb 25, 2010 | 1996 Toyota Corolla
Ken Tech Large Digital Atomic Clock T4668 Logo
256 people viewed this question
Top Ken Tech Audio Players & Recorders Experts
cwradio73
Bart Walker
Tom Chichester
Are you a Ken Tech Audio Player and Recorder Expert? Answer questions, earn points and help others
