Error code 20000-0146
Imge recovery
Unbrick galaxy tab 2 Verizon sch-i915
go to the directory of the downloaded files. shift-right-click and choose open command window here go into device manager and right-click on OMAP4430. Click choose a file on the disk, and go to the OMAPFlash Recovery p5113/usb_drv_windows. once the driver is installed, go to the command prompt and type Code: OMAPFlash.exe -v fastboot flash recovery recovery.img copy the text from the command prompt and put it on this thread. Here's the OMAPFlash download: V1 NOT WORKING https://www.dropbox.com/s/hg1qauhhl7...ry%20p5113.zip V2: for p5100 ONLY
May 21, 2014 | Cell Phones
Pls help me; my hp pavallion g6 loaded with windows 7 boots with a white screen no d
May 08, 2014 | HP Pavillion G6 1d72nr I3-2350m 15.6"...
My hp touchsmart tx2 -1377nr notebook has no t kernel img windows and no boo
Hi I hope this we help you.
First check all programm menu and locate hp security folder in it you find recovery manager click on it and restored your computer to factory settings. if your computer has corrupted to the extent that the process stop then restart your computer at the process of booting strike on escape key on your keyboard to enter into series of procedure, which will indicate (f2, f9, f10, f12) with their respective actions strike on the function key that is set for recovery manager then follow the process. I believed this should resolve your issue.
Feb 24, 2014 | HP Mini 1000 Netbook
I HAVE A PROBLEM(errore sc-552) WITH MY COPIER Ricoh Aficio 2027 All-In-One Laser Printer
found this solution on line -Ricoh Copier Error Code SC 552 is Fusing thermistor error 2 problem
1. Fusing lamp is not connected angry.gif:(" title="Angry"> (reconnect it)
2. bent or is bad [img src="http://copierliquidationcenter.com/Copier_University/Smileys/default/angry.gif" alt=">:(" title="Angry"> (replace it)
3. Thermistor position incorrect [img src="http://copierliquidationcenter.com/Copier_University/Smileys/default/angry.gif" alt=">:(" title="Angry">
Try to reset this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
.... if this is not working, you might need new Fuser Thermistor ... go to Copier Parts Outlet.com find your copier, order your copier thermistor .... they have YouTube videos how to replace them too ...
Try this Video first:
youtube.com/watch?v=2S_jH3MOwr4
Jan 14, 2014 | Computers & Internet
Itouch disabled
To put the iPhone into recovery mode so you can do an iTunes firmware restore follow these steps:
Step One
Open iTunes and connect the iPhone to your Mac.
[img src="http://www.iclarified.com/images/tutorials/367/1350/1350.png" width="128" height="128" border="0" alt="">
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
[img src="http://www.iclarified.com/images/tutorials/367/1349/1349-500.png" width="500" height="127" border="0" alt="">
Step Three
As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
[img src="http://www.iclarified.com/images/tutorials/367/1351/1351-500.png" width="500" height="204" border="0" alt="">
THEN CONNECT ITUNES AND UPDATE
Nov 11, 2013 | Apple iPod Touch 8GB 32GB 64GB 3rd...
I have a baxi bermuda boiler what does error code E155 mean
<a href="http://affiliate.buy.com/fs-bin/click?id=v4pjWTHB5dE&offerid=245038.210581578&type=2&subid=0"><IMG border=0 src="http://ak.buy.com/PI/0/1000/210581578.jpg" ></a><IMG border=0 width=1 height=1 src="http://ad.linksynergy.com/fs-bin/show?id=v4pjWTHB5dE&bids=245038.210581578&type=2&subid=0" >
Mar 18, 2012 | Heating & Cooling
CLC 5100 error code: E194-0101
Go to Service mode (Function _ Install _ 2nd Screen i.e. 2/4 make img reg 0 Restart machine Again Go to intall press init c aftrer complition press sinitc aftre getting it ready again make img reg to "1"
Jul 19, 2010 | Canon CLC 5100 Copier
Text Error 1121611611
In order to send a text message on the iPhone, you must have the entire 10-digit phone number in your phonebook. For example. If you are trying to send a text message to the phone number 555-1234, you must also enter the area code. If the area code it 412, you must put in 4125551234 for the phone number.
Hope this helps!!
Nov 14, 2008 | Apple iPhone Smartphone
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
