Question about Air Tools & Compressors
20 gallon champion air compressor porta-champ manual
compman66
  • 169 Answers
SOURCE: champion vr3-8 auto drain blowing out when compressor turns off
If the air continues to come out on top of the drain valve well after the pump has stopped, you may have a faulty tank check valve where the pump discharge line enters the tank. when this valve sticks open it will cause this problem.
Posted on Nov 26, 2009
compman66
  • 169 Answers
SOURCE: Hi, I bought a used Air Ace air compressor. 5 Peak
send me a photo of the compressor and if there are any model numbers or serial numbers and I will see if I can identify the pump for you. my e-mail is steve@morrismachineservicesllc.com
Posted on Jan 15, 2010
Testimonial: "I will get that info over the weekend and sent it to your e-mail Thanks"
SOURCE: Jobmate 3 gallon air compressor parts list/diagram
Good luck on this one. I own 2 jobmate compressors, one I bought and used very little before it blew apart and another a freind gave me to use for parts. Guess what the same part failed on both and I know of at ;east three more that also failed the same way.
I gave up trying to deal with Canadian Tire and Jobemate and junked them, as though they weren't junk to begin witn. You get what you pay for. I have a new Hausefield compressor and it is fantastic.
Posted on Jun 22, 2010
SOURCE: I have an 60 Gallon Air Compressor Husky Pro, no
Read the owners manual,look at the motor label
20Amp is usually for 2HP and may work for your 3.2
Look at full load rating on motor. You won't need a
breaker that high.
You will need 12 ga wire and 20 amp breaker min.
two wire 240 volt circuit.
It should be wired for the higher voltage,if not look at the
inside of the small motor cover and move the terminals
to the two pole rating. Expensive to run at 115volt
Posted on Nov 25, 2010
H2_Brad
  • 425 Answers
SOURCE: champion air compressor pump model m-1820 ser no
I believe that m1820is actually the part number for the crankcase. I think it is the same unit as the Dayton brand. Look at this link for a parts list.
http://www.grainger.com/Grainger/rp_parts_list.jsp?xi=xi&lastProdSearchCriteria=7095529&mfg=SPEEDAIRE+BY+DAYTON&model=1WD46&info=&desc=5hp+Duplex+Air+Compressor&supp=20002571&save=1
Posted on Jul 18, 2011
Need manual for air compressor 5 rca
That is made by Gardner Denver under the same model number. I could not find a manual for it but here is their site. I would contact them and see if they can furnish you one.
Gardner Denver
Aug 25, 2012 | Champion International Champion 2 Stage...
Where do I get a cylinder head for a clarke champ air compressor model #AC2001B?
This company in liquidation in the US, however many of the same compressors are available in the UK re-branded with different model numbers/names (alpha name instead). Go down the list opening manuals until you find similar looking parts. You may find same pump/motor components on a different tank, however use manual information as needed. China made compressor as yours will be sold by many different retailers under different names. Look on ebay first "searching pancake" compressor for likeness. The manuals listed below should clue you in. Good luck.
http://www.clarkeservice.co.uk/product_manuals/air_compressors.shtml
Sep 19, 2011 | Clarke Power Products Inc AC2001 2HP 4...
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Compressor not cycling and building pressure after servicing
Hi
I suspect you may have either overfilled the sump or used the wrong viscosity oil, may have splashed up onto valves and patially jammed one open.
Aug 11, 2009 | Champion International Champion 532 2...
Air Tools & Compressors Logo
475 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
