Question about Juki DDL-8700
Thread Breaks I just set up my machine and threaded it according to the video. My thread keeps breaking. I tried adjusting the tension but for some reason it keeps breaking. I doubled checked my threading and it seems to be fine. This is frustrating since I am not familiar with this new machine
  • 64 Answers
Tilt machine on bed and run you finger around the hook checking for burrs. use emeory paper to remove any burrs. rub around the hook not across!! your thread could be cheap and not bonded, it may be splitting when the hook grabs it. also loosen the tension on the bobbin case so u will not need so much tension on top. is your take up spring in the right position with just a little tension?
Posted on Jun 14, 2014
Zenqi
  • 208 Answers
SOURCE: the top thread keep breaking. should the tension
Thread breakage is usually due to the needle in backwards, upper tension too tight or old/weak thread.
When replacing the needle, make sure that the flat side is to the right (3 o'clock position) and is pushed all of the way up before tightening.
What brand and weight of thread are you using and are you sewing with the foot or free motion sewing?
Posted on Jun 17, 2009
SOURCE: Juki TL98Q needle thread breakage
Use a thread stand and rethread.
Posted on May 23, 2010
flipbooks
  • 177 Answers
SOURCE: During free-motion, the thread tension plates
Here's a page on the FixYa site that has only Juki solutions. Someone here may have solved your problem.
http://www.fixya.com/support/juki
Also, you can get a free copy of the service manual here:
http://www.juki.co.jp/household_en/pism/img/tl98q/download/98pqsm.pdf
Posted on Apr 06, 2011
  • 1564 Answers
SOURCE: janome sewing machine thread breaks while quilting
Check for burrs. Even the tiniest burr can break thread. Check the needle throat plate, the bobbin area...
Get out your magnifying glass and really inspect it. If you find a burr... carefully smooth it down with some very fine (1200 grit) sand paper.
Posted on Jul 20, 2012
  • 1564 Answers
SOURCE: I have a Juki DDL 227. Top thread keeps breaking instantly
Well, you've not checked "Everything" but you have checked the common things.
Do you have any idea of where it is actually breaking? Re-thread your machine and see if you can determine exactly where the break occurs.
Sometimes a damaged needle throat plate will break threads... as will a burr on the hook in the bobbin area. Also if there is a burr or rough spot on the thread spool it will sometimes catch and cause breakage.
Good luck
Posted on Jul 23, 2012
Top thread keeps breaking. Adjusting the tension does absolutely nothing. It seems as though the thread is getting caught on something inside the machine between the thread guide and thread take-up lever....
these are suggestion, if they don't help then the machine needs to be checked at a sewing machine shop
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Sep 27, 2013 | Euro-Pro Sewing Machines
Kenmore serger thread keeps breaking
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Mar 26, 2013 | Sewing Machines
My machine keeps breaking the thread
Mar 02, 2013 | Sewing Machines
My thread keeps breaking and the bobbin tension is too loose
adjust the top thread tension one number or letter higher at a time
and sew on a scrap piece of fabric till the stitches look normal
The needle thread breaks
Jan 15, 2013 | Sewing Machines
THE COTTON KEEPS ON BREAKING EACH TIME I WANT TO SEW
8. try a different thead
9. try adjusting the top thread tension
Dec 20, 2012 | Sewing Machines
THE COTTON KEEPS ON BREAKING EACH TIME I WANT O SEW WITH MY YAMATA FY940
8. try a different thread
9. try adjusting the top thread tension--to a lesser number or letter
use your manual to guide you through tension adjusting
Top thread pulls and breaks while sewing.
Oct 24, 2012 | Sewing Machines
I have a brother vx-1125 the cotton keeps snapping..but the tension is correct..please advise..
Aug 17, 2012 | Janome Sewing Machines
My thread uptake lever keeps coming unthreaded. It causes stitches to be skipped and eventually the thread breaks. I have adjusted the tension, it doesn't help.
take up lever--try putting some tape on it to see if that will stop the thread from coming off.
also change the needle--make sure is the correct one for the fabric
Apr 14, 2012 | New Home Sewing Machines
Bobbin thread breaks. sounds like clicking while sewing
hi there,
pls, the see the figure how bobbibs thread directionc21dcd7.jpghave you seen theres a screw on latch body case of bobins,you can adjust this but mostly this is factory
adjusted,bobbin tension can adjust here.but try to follow the thread direction.set up again the dial setup tension to #3 and stitch to #8 to #12.bobbins slip due to accumulation of thread under
bobbins.hopefully this may help you to continue sewing.
have a nice day,
Apr 18, 2009 | Sewing Machines
Juki DDL-8700 Logo
74 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
