Question about Panasonic PT-47WX51 47" Rear Projection Television
Panasonic 47 Rear Projection TV
Hope someboby out there can help. TV now 4 yrs old and is a great set. Recently it has been changing skin tones especially to a horrid lime green. The effect only lasts for 5-20 seconds, some days not at all and others a few episodes over a few minutes. The picture / convergence are all fine. I want to knock this on the head before it becomes a real problem. Regards, Ron Huston
  • 3 more comments
  • Ron Huston Aug 07, 2007
    Mike - many thanks, I guess the front just pings off or does it have secert fixings, or does the back have to come off first???
    Regards
    Ron
    Mike - thanks again - am a mechanical engineer with lots of hands on factory experience. Ill pull the front off in the next few days and will send you a picture for further guidance.
    Regards
  • Ron Huston Aug 12, 2007
    Mike,
    Cover off as per photo. Which is the Red Gun?
    Each gun has a board up at the neck and one at the base of the gun
    Regards Ron
  • Ron Huston Aug 18, 2007
    Mike,
    I assume we are talking about the board attached to the base of the gun(and not the one attached to the neck) Each has a metal cover over the solder side of the board. I assume this has to be removed, then all solder joints remelted with a small solder iron- does the cover have to go back on?
    Regards
    Ron
  • Ron Huston Sep 02, 2007
    Took the board off, removed/reconnected all plug in connectors. The main connection ie. board to gun was a little wobbly and the pins at the bottom of the gun showed a purple look = heating. From my lighting days that oxide film indicates a connection not running at 100%. Gently cleanded off film with some 600 W&D sandpaper. No green for a couple of weeks !!
    Genius:
  • 1,153 Answers
You say changing skin tones and green problem. Well it sounds like CRT maybe going. Have this set been used for gaming? (Playstation, XBOX, etc) If so this has alot to do with it. Also you can see problems like this if loose connection around crt boards(on neck of tubes) check all three good. sometimes you can tapp on slightly and see a change. Use something rubber and be careful not to damage yourself or anything else.
Posted on Sep 04, 2007
  • 398 Answers
Usually what I find in a case like that is that there is a loose solder joint on the CRT board of the red picture tube. When the connection is good the picture looks fine but when it lets go the picture turns that awful greenish-blue. On most sets the bottom front of the TV will disassemble to allow access to the CRT boards, and the solder joints can be resoldered quite easily. If you do not have experience resoldering boards in a projection TV then allow a qualified tech to handle it for you.
Posted on Aug 07, 2007
  • 2 more comments
  • Mike Longo
    Mike Longo Aug 07, 2007
    On most sets the front just pulls off, being held in place by little rubber or velcro fasteners. Pulling on the sides gently is all that should be required. Then there might be a panel that comes off by removing some screws, revealing the bottoms of the 3 picture tubes with their CRT boards. Obvoiusly, make sure the TV is unplugged when doing this!
  • Mike Longo
    Mike Longo Aug 12, 2007
    From that picture, red is usually Gun 1, the tube on the left. Green is always center and in Sony sets, the blue is always the right one. Turn the set on and look at the top of the picture tubes and it will be very obvious which one is red.
  • Mike Longo
    Mike Longo Aug 18, 2007
    Yes, we are talkimg about the board at the base, with the shield soldered on. You must remove the shield to resolder the connections under it. When resoldering, the most likely places for a failed joint are the transistor on the heat sink, the tube socket itself and the jacks where the wires connect to the board. The board is small so it is easiest to just go ahead and resolder them all. Use a small soldering pencil and some good 63/37 rosin core solder. Although it is not absolutely necessary to put the shield back (99% of sets do not have shields), I would replace it, especially since it is easier to put it back than it is to remove it. Inspect and resolder the solder joints on the other boards as well. Usually there are wires between the boards so a loose connection on a jack on the green board can cause the red board be intermitten.
  • Mike Longo
    Mike Longo Sep 03, 2007
    I do hope that by "no green for a couple of weeks" you mean no abnormal green, and that the green in the picture is only where there is supposed to be green. In that case, I say "great job!"
SOURCE:
Model LGXBR446 VCR/DVD Recorder, Have to go input on the TV to get the unit to Play, Does not play Automatically when turned on an disk or VCR inserted, Also the color is not correct
I think I know what the "skin tones blue" problem is-you probabaly have the composite video(for the old video-on-one-cord format) connected to the blue of the component video input.(component video is the red/blue green RCA type connectors).
May 31, 2012 | LG XBR446 DVD Recorder/VCR
Please tell me best moisture for slightly oil skin esp in summer ? 53 yrs old and would like to try micro sculp cream ....doesn't feel greasy but is it recommended for my skin type ?? would love any...
Artistry Time Defiance Daytime Protection Lotion - SPF - Combination-to-Oily Skin is a great daytime moisturizer if you have have slightly oily skin.
The ultimate anti-aging daytime lotion to defy age beyond procedures. This intense daytime moisturizer with SPF 15 stops aging where it starts. Daytime Protection Lotion visibly reduces the appearance of wrinkles by more than 50% in 12 weeks.
http://www.amway.com/sorenson/Shop/Product/Product.aspx/ARTISTRY-TIME-DEFIANCE-Daytime-Protection-Lotion-SPF-15-Combination-to-Oily-Skin?itemno=101822
Mar 11, 2012 | Health & Beauty
How do I install my dish network satellite to my new 47" panasonic?
We would be happy to help you with that. We would recommendvisiting our "Set up receiver to TV"page here:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. We hope thisinformation helps you. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 18, 2011 | Panasonic PT-47XD64 47" Rear Projection...
I'm looking for SD Tech. The answers he's providing for a panasonic 47" projection screen are great. I need more technical info
Not easy on this "Fixya" site to get in touch with people.. Not impressed with the site layout at all.
I saw a post by him somwhere on here that stated to say something like "Help SD Tech" or something in the subject, so hopefully he will search for his name? and find that people are looking for him. Pretty inefficient, but I can't even post a question through 2 browsers, so I must be missing something myself.
Good luck, hope you find him, but if you have this TV, there is a great tutorial outside of Fixya here:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Hope this helps!
Oct 19, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Sony klv-40w400a has a strange green tone
Okay would love to help you with this issue but most good reults if you choose to chat with me! The prblem with these color changes are most have to due with the aparatus your connecting to the Tv and not the Tv itself. But if you got it on all things its a decoder issue have the tech check the decoder. You will be glad you did.
Please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 21, 2009 | Sony KDL-32S3000 32 in. LCD Television
I have a panasonic 47" widescreen about 5 years old. Recently turned it on and all 4 corners are missed aligned and a faint line going through the middle. Tried setting the convergence with all of them...
Yes, the convergence output IC's have gone bad. They need to be replaced. This is a very common problem with all projection tv's. It is the job of those outputs to properly align where the red, green and blue beams land on the screen.
Jun 06, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Only yellow,blue & green colors, occas hint of red. What are correct settings? middle of gauge,
sounds like degausing circuits bad. unplug for couple of hours. if this doesnt work try waving a heavy magnet in front of tv about 2-3 inches from screen.
Jun 01, 2009 | Philips Magnavox MT1905B 19" TV
Sometimes has green tint.
YOU ARE 100% CORRECT it is the cameras ....... as a tv camera wears out green is the last to get weak . so the picture turns green crt tvs do the same thing
Mar 25, 2009 | Sony Televison & Video
GVA TV
I have a GVA TV problem with his remote First four minutes it work properly then stop working. Batteries replaced many times still same problem. Give the solution.
Jan 12, 2009 | Televison & Video
Hello , I just purchased a 26" Toshiba LCD/HD flat screen TV today. The floor model had the nicest picture at Circut City of the other 26" TVs - but they were hooked up to receive HDTV. When I got it home,...
Yes, the newer flat panel TV's look great with HDTV but amplify the substandard analog TV signals.
I would compare the non HD to VCR quality. If that is what you are seeing then this is normal with non HD broadcasts (typically the channels 1-100).
Hope this helps, please rate my solution.
Jan 11, 2009 | LG 42LG50 42 in. LCD HDTV
Panasonic PT-47WX51 47" Rear Projection Television Logo
76 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
