Question about Westinghouse " 46"" Class - LED - 1080p - 120Hz - HDTV LD-4655VX"
Midddle bottom has black shadow and getting bigger
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Sony Bravia LCD black shadow screen
You may ahev failing T-CON board, try having a small fan blowing at the vent on the back of the TV. If you can post pictures it will help a lot.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 28, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Feather like shadows on bottom of the screen JVC HD-61G887
This is convergence problems at it worse.U must have soldering tools,solders and know how to do soldering to solved convergence problems.Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for the parts and labors.
May 16, 2010 | JVC AV-56WP30 56" Rear Projection...
Pistons
have you checked ebay or another online source? There are also several motorcycle salvage companies that may have the part available
May 02, 2009 | 1988 Honda VT 1100 C Shadow
Shadow along side
does this shadow go from top to bottom on the left or right side app 1" to 2" wide ? if so your light engine needs to be replaced
Jan 17, 2009 | Toshiba 46HM95 46" HDTV
1987 dodge shadow removing water pump
This help? click on link below. When you get there and want bigger pictures, click on them.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528018dabb
Jan 06, 2009 | 1987 Dodge Shadow
I have a 56 inch JVC HD TV model# HD-56G647. yesterday when I turned the set on there was a black shadow in the lower hand corner. today it's bigger. i called jvc and they told me to make sure the...
Red light lamp indicator is blicking on my 56 inch mode;# 56G647 tv and the Tv screen is black with no vision of tv and no sound. What sould I do
Oct 17, 2008 | JVC Televison & Video
Rear projection lg lcd 44 inch
Is it an LCD or DLP? The Model below suggests it is an DLP. Sounds as if you have the dreaded light tunnel collapse common to all LG DLP TV's. Inside the light engine there is a square tube made up of four mirrors. These mirrors deform and crack with the heat of the lamp. They fall down over the light aperture and cause a shadow of varying degrees. It is fixable now at a realistic price ( used to have to replace engine) as LG have made the parts available. It would take a competent tech around three hours to complete or if you are technically minded you could do it yourself. I hope this helps. Good Luck.
Sep 29, 2007 | LG RU-44SZ51D 44" Rear Projection...
Westinghouse " 46"" Class - LED - 1080p - 120Hz - HDTV LD-4655VX" Logo
18 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
