Question about Tools & Hardware - Others
Milomex ltd Bought the above Staple Gun from Lidl and they say to contact Milomex for a further supply of staples.
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
lessmith49
  • 5 Answers
SOURCE: see above
317b762.jpg4a538aa.jpg067f3f0.jpg5077a62.jpgca392ef.jpge76904e.jpg77309d5.jpgThis is an older b&d stapler but the designs are similar in most cases. The position of the springs, and the order you put them in, are an obvious factor.
The parts that overlap go in after the parts underneath.
When you have one half assembeled you should not have to force the cover to go on, it should just sit in place while you put the screws back in.
If the handle coil spring and the flat spring are not seated properly the top cover will not go on easily.
These types of staplers are designed to clear from jamming without being taken apart, the staples, under normal circumstances, do not have access to the body of the unit past the flat spring.
As with any tool forcing the tool after a fault will only make matters worse, I would try some light oil or spray lubricant first before taking anything apart, these springs can be a pain to get back in, which is why I have not taken this one any further apart. Hope this helps you. If it does please let fixya know.
Regards
Les
Posted on Feb 12, 2009
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
Where do I find staples for the above Ace 2025 staples?
Most staple guns accept a range of staples of a standard type available from many different suppliers. It is rare that a staple should be manufactured for the exclusive use of a single staple gun.
First you need to know the sort of staple you need. Unfortunately staple gun manufacturers tend to omit this information from their literature and instead use the part number they have allocated rather than the more universal information of type and size.
Fortunately many nail and staple suppliers catalogues contain useful drawings with sizes so identifying any staple, once it has been very carefully measured, fairly simple.
Apr 19, 2016 | Staples Tools & Hardware - Others
I bought a hammer staple from lidl wher do I get the staples from ?
Google search make, model and manual if you do not have the manual at hand. Staple size will be in the manual, and many times will be on or inside the staple slide. They should be available locally from any hardware store.
http://www.lidl-service.com/cps/rde/SID-8C181B36-F49FF6CE/lsp/hs.xsl/product.html?id=8000278&title=Kladivov
Mar 09, 2015 | Staples Tools & Hardware - Others
What Staples does a swingline 34301 Electric Staple Gun take?
That's an easy one
Use the Arrow 600 series staples. heres the link to the different sizes available.
http://www.arrowfastener.com/catalog/supplies/staples/600-series
Good luck and don't forget to rate me :)
Aug 09, 2014 | Staples Swingline® 36115 Staple Guns Tools...
T50 elite wont staple
I just bought a T50 elite, and it will NOT staple too.
Simple 3/8" staples loaded and nothing comes out.
Jan 31, 2012 | Arrow T50P ARROW STAPLE GUN
No instructions came with the stapler and the . I can't get it open to install staples! I need this now. You start a project and can't get what you need! I was expecting more from a product...
Open the PowerShot staple gun staple chamber. This is found on the front of the staple gun. There is a small metal area on the bottom. Pull down on this and the interior of the staple chamber is revealed.
  • Remove any existing staples that may be in the chamber. These can be pried out with your fingernail, or you can turn the staple gun upside down and gently shake the staples loose.
  • Slide a new row of approved staples into the PowerShot staple gun. These need to be slid in from the base of the staple gun (where you pulled the cover of the chamber off).
  • Close the cover to the PowerShot staple gun's staple chamber and you are ready to use your staple gun on the next household project.
  • May 07, 2011 | Powershot Tool Company Tools & Hardware -...
    Need help loading staples in my Stanley electric staple/nail gun
    there should be a button / lever at the rear press it and it should open so as to insert the staples
    Apr 05, 2010 | Stanley Staple/Nail Gun Elec
    Broken part in Stanley Heavy duty Electric Staple/Nail gun
    Bought a new one. Stanley hold no spares in this country, so it was cheaper this way! I am disappointed it broke so easily, so soon in its proper life. The part that failed seems poorly designed to me.
    Nov 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
    Powerfast staple gun works poorly
    Gun is most likely a multi strike gun. Try not moving the body of the stapler and pushing the strike lever again, repeat if necessary.
    Dec 20, 2008 | Watts Brass Pipefast Staple Gun Pipe To...
    Powerfast strap gun for romex misfiring
    just a try spray with a generous coat of pb blaster while firing a few then follow with a good coat of household oil then oil before using just something to give it a try
    Nov 17, 2008 | Tools & Hardware - Others
    Tools & Hardware - Others Logo
    51 people viewed this question
    Top Tools & Hardware - Others Experts
    J.D. Browning
    J.D. Browning
    Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
