Question about Kenmore 56 oz. Blender/Food Processor - Black
Need blade 202300333 - Kenmore 56 oz. Blender/Food Processor - Black
How do I remove old blade?
Hi Paul,
There is a collar on the base of the jar that screws onto the jar. You will need to unscrew the collar and fit a replacement blade. make sure the seal is replaced with the blade and the collar is screwed back securely.
See this link for the parts of the blender.
CUISINART CANADA SmartPower Premier 600 Watt Blender CBT 500C
Also see the product description for the blade.
https://www.youtube.com/watch?v=rdBxUAsT_TQ
Mar 04, 2015 | Cuisinart Replacement Cbt-Bg-1 Blender...
How do I put the blade on my Ostis PowerMax clippers? I have tried with it on and off with no success. Thank you.
The blade release should be under the heel of the blade, just below where the blade tongue hinges. You normally only need to press it when removing the blade, when snapping the blade shut it is mostly not necessary to push it. They are a bit like a door latch that self lock when closing.
Feb 17, 2015 | Oster PowerMax 2-Speed Clipper Kit
Kitchenaide blender pitcher blade assembly sticks
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
How to lubricate blade assembly.
Oster clippers
it could be metal fatigue from the blade. Try a different blade and see if it does the same. If it is still rattling it could be your blade drive needs to be replaced. Sometimes the screws that hold the blade drive in place come lose or striped so you may need to check them.
Apr 23, 2013 | Oster Turbo A5 Two Speed Clipper - Blue
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
My blender is leaking slightly from underneath the blade. Is there a way to tighten the blade coupling?
I am guessing you have a KSB52. If the leak is through the blade spindle then tightening won't help. The "wingnut" is tightened through use anyway. The most likely cause is a failed seal. The whole blade unit will need replacing, search Amazon for 9704291
May 04, 2011 | KitchenAid KSB560 5 Speed Blender
How to change the blade
You can't. The Jars have perfectly balanced blades that cannot be changed. A replacement jar from Blendtec is cheaper than a replacement blade assembly from other manufacturers. 1-800-253-6383 is the customer service number.
Jun 04, 2010 | Blendtec Smoother Work Top Blender
A blade on my immersion blender was bent slightly. The motor still works and the blades spin, but they no longer emulsify. Can I buy just a new blade attachment?
If you have a model with the detachable blades. Otherwise, you'd need to purchase the blending rod from www.wpcookware.com.
Jan 16, 2010 | Wolfgang Puck Immersion Blender
Kenmore 56 oz. Blender/Food Processor - Black Logo
Top Kenmore Blenders Experts
eyecam
Are you a Kenmore Blender Expert? Answer questions, earn points and help others
