Epson sx150 flashing ON light and lines across printing
gwbm
  • 353 Answers
SOURCE: Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Posted on Mar 12, 2009
SOURCE: EPSON STYLUS DX3800 PRINTS PHOTOS WITH HORIZONTAL
how do i reset epson dx3800 printer
Posted on Jun 06, 2009
aicaxz
  • 511 Answers
SOURCE: Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Posted on Jun 10, 2009
aicaxz
  • 511 Answers
SOURCE: printer keeps printing lines across the page of 1
Width of head sprayer (head output) of black is about 1". Check nozzle. It might be some point of head spayer distort. See check nozzle ouput. There are tranversal and vertical lines that represent same point of head sprayer. Is the output perfectly straight and no clog at all? Do head cleaning procedure.
Posted on Aug 21, 2009
rioglen
  • 95 Answers
SOURCE: my epson r220 printer is printing yellow
it maybe because your printers nozzle might be dirty. try to perform some cleaning cycles about 3 would be more effective......
Posted on Sep 10, 2009
Hi, When printing photos, my photos have horizontal light coloured lines across them. When I print the nozzle check pattern all colours match the guide with the exception of the light magenta....
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others http://www.internet-ink.co.uk/epson-cleaning-cartridges/ http://www.icompinkcartridges.co.uk/epson-r200-r300-r220-r320-r340-cleaning-kit.html
Jan 03, 2011 | Epson Stylus Photo R200 InkJet Printer
Photo R200 won't print
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson Stylus Photo R200 InkJet Printer
After every line of black text there is a light blue line.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Feb 01, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Printer keeps printing lines across the page of 1
Aug 21, 2009 | Epson Stylus C84 InkJet Printer
Lines appear across the photo when you print it
Try running the head cleaner function a couple of times.
That should solve your problem.
Feb 24, 2009 | Epson Stylus 1400 InkJet Photo Printer
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Light Flashing
print a test page and allign the cartridges from printer maintenance....
Aug 10, 2008 | Epson Stylus 880 InkJet Color Printer
jasbo
jasbo
