Question about HP Compaq Business d530 Small Form Factor PC Desktop
HP DC5000 SFF
This is a small form HP desktop, I bought it from work through a off-lease purchase program. When I hooked it all up and hit the power button, it went "pghtzzt" and now it gives no indication of getting power. Spoke to a few people, all said, "Bad Power Supply" or, "It might have an interal 'fuse/reset' button. Does this system have a fuse, and/or a reset button? I've priced out the replacement power supply, and would rather not go down that route if there is a simple reset button somewhere?
I have the same computer HP DC500 SFF and It was doing the same thing... After I had turn off a switch itnstarted beeping five times and pause and then kept with the same routine... I came in here and read about this posts... I got the idea of opening the computer and check the CPU fan, it was really dusty, so luckily I had a power duster.. I clean the fan made sure it was well seated and whala!!! Computer is running finenand sounds even better now... The fan sound is really soft.. In other words like new...
Posted on Jul 30, 2011
    Problem Solver:
  • 4 Answers
The power supplies that came in these are junk. Every one of them i've had did the same exact thing, something shorts out in the power supply then its dead, you replace it and a month later it blows again. I'm going to take 2 bad ones apart tonight and see where the problem lies and see if i can't fix whoevers bad engineering..
Posted on Nov 13, 2009
    Sergeant:
    Champion:
  • 326 Answers
Look inside the ps, it will have a small glass fuse. Have the unit unplugged from the wall first and out of the pc shell.Try replacing the fuse and plug only the motherboard connection to trun it on. If the fuse blows again... replace the ps. if it holds then turn it off and reinstall to ps. if it blows again... do one connection at a time to find the bad device. Good luck.
Posted on Dec 13, 2007
I can I find out if my computer has a wireless card
Posted on Dec 11, 2007
    Scholar:
  • 161 Answers
Well it could very well be the power supply. But it wouldn't hurt to test it with another power supply first just to see. Open it up and unplug the power supply from the board and plug up another power supply from almost any computer and turn it on and see if it lights up. You will have to plug up the hard drive to if you want to see if your hard drive will work and you can even plug up your cd roms too. If after you plug up a working power supply and you get nothing then you know it could be the board, the processor, or just a hard drive or cd rom setting not set right. Or it could simply be the extended memory. It can be alot of different things. You just have to start somewhere until you find it.
Posted on Aug 07, 2007
  • Jessie Goss Aug 12, 2007
    If the unit doesn't have a reset button then you can look on the board for a reset jumper.It will have jumper 1 2 3 pull jumper connector from 1 2 and place it on 2 3 then reset it back to 1 2 and then try your computer.
SOURCE:
How do I get the cover off an hp compaq dc5000 SFF?
HP Support > HP Compaq dc5000 Small Form Factor Desktop PC > Manuals download page,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=403745
Service and maintenance information,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=403745#2
Click on -
HP Compaq dc5000 Series Service Reference Guide 2nd Edition
(2 Apr 2004 / 4.61MB)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds before the first page comes up.
Removal and Replacement Procedures - Small Form Factor (SFF) Chassis - Page 95. (Page number box at top )
Page 98 -
"2) Pull up and hold open the latch on the top of the computer."
"3) Slide the computer access panel back about 0.5 Inch (1/2 Inch, or 1.3Cm), then lift off the unit."
The Access Panel has tabs formed out of it's sheet metal construction. These tabs have a hooked end. The hooked end must be brought towards the back of the computer, so it will be free of the matching slot in the metal frame of the computer case.
Then it can be lifted up, and off.
Included the Service Manual, for questions you may have in the future.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 01, 2012 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
Can I upgrade CPU to an Intel Core2 Quad processor on the HP Compaq dc5000 Small Form Factor PC Desktop?
Can I upgrade CPU to an Intel Core2 dual processor on the HP Compaq dc5000 Small Form Factor PC Desktop?
Jan 27, 2011 | HP Compaq dc5000 Small Form Factor PC...
I need driver controler ethernet for hp compaq dc5000 sff
HP Compaq Business Desktop dc5000 series ... All dc5000's come with: Intel 865GV chipset ... Integrated Broadcom NetXtreme Gigabit Ethernet for HP try this link for the driver you require
http://www.general-search.com/download/controleur-ethernet-hp-compaq-dc5000-sff
Apr 30, 2010 | HP Compaq dc5000 Small Form Factor PC...
Fan sounds like a dc-20 aircraft!
Yes u can it will wont harm ur computer, but remember to switch off the computer and bring out the main electrical cord out of the main before u start ur work.
Apr 22, 2010 | HP Compaq dc5000 Small Form Factor PC...
Downloading video controller (VGA compatible) for hp compaq dc5000 sff
goto this site http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=dc5000&submit.x=0&submit.y=0 you have a choice of micotower or small-formfactor - click on your machine Then you will be asked to choose windows version I went to XP and had the choice a few graphic driver
Apr 13, 2010 | HP Compaq dc5000 Small Form Factor PC...
I have a HP DC5000 sff and the power light flashes 3 time
Usually means that a processor is not installed or not installed correctly.
Nov 25, 2009 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
I have a HP DC5000 SFF. It won't power on and I
Unplug the unit from the wall for a couple of hours to see if the unit will reset and turn on.
If it won't turn on after a couple of hours please post back.
Regards.
Aug 01, 2009 | HP Compaq dc5000 PC Desktop
HP DC5000 SFF
Check the cables connection first.
Check if the power supply fan and cpu fan are working
If not you need to replace your power supply.
Let me know how it is going!
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 17, 2008 | HP COMPAQ BUSINESS DESKTOP DC5000 SFF - 1...
Open Questions:
+1_855_892_0060 Apple Customer Service '' Apple Customer Support Number +1_855_892_0060 Apple Customer Service Phone Number '' Apple Customer Service Number Apple is a great platform for unlimited entertainment, only having a membership plan; you can dive deep into the entertainment world. But is this always possible? Not at all, you have to face various issues with this every now and then, but you will be happy to know that Apple Prime Customer Support service is 24*7 active to assist you whenever you experience any sorts of issues with this. Yup! No hassle, no waiting, your every single issue related to Apple will be resolved instantly at a single call to customer support. chat with Apple customer service.USA DAIL Itunes customer Care number our ensured specialists are available constant to offer most sensible courses of action immediately even by methods for our toll free number for Canada and USA.is advancing strong responses for the customers by methods for customer organization as it appreciates the burden and frustration a customer needs to encounter. It is advancing game plans by methods for different sources so the customer can pick the right one according to his tendencies. Itunes technical support. Our submitted gathering of is just a phone way and accessible immediately relentless. Itunes customers can come to us to benefit answers for any of their issues including the ones referenced here under Itunes best without toll number, there are 4 outright ways to deal with associate with them.The accompanying most perfect way to deal with banter with their customer reinforce gathering, according .Ipad Support Avail Ipad Support To Quickly Resolve All Ipad Errors Independent Ipad Support Phone number for Ipad Help The line of tablet computer designed, developed and marketed by Apple Inc. APPLE Customer Service Number +[{1855-892-OO6O*}] to resolve all APPLE products. APPLE is an American multinational company which was founded by Michael APPLE using its company headquarters in Round Rock, United States of America. Contact APPLE for Setup & Installation APPLE Setup Free & Installation APPLE CUSTOMER FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for APPLE Connect, APPLE CUSTOMER Free Phone Number you'll be searching out APPLE Connect setup as well. So, here we're with all cthe setup process and for your to APPLE Connect. Get APPLE Setup Instant Free APPLE CUSTOMER FREE Phone Number Usually, the setup CUSTOMER nique takes a number of time. One CUSTOMER nique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't CUSTOMER-savvy. Let us undergo the method of APPLE Connect setup for Windows and for Mac. So, right here we go hayabanApple is a great platform for unlimited entertainment, only having a membership plan; you can dive deep into the entertainment world. But is this always possible? Not at all, you have to face various issues with this every now and then, but you will be happy to know that Apple Prime Customer Support service is 24*7 active to assist you whenever you experience any sorts of issues with this. Yup! No hassle, no waiting, your every single issue related to Apple will be resolved instantly at a single call to customer support. chat with Apple customer service.USA DAIL Itunes customer Care number our ensured specialists are available constant to offer most sensible courses of action immediately even by methods for our toll free number for Canada and USA.is advancing strong responses for the customers by methods for customer organization as it appreciates the burden and frustration a customer needs to encounter. It is advancing game plans by methods for different sources so the customer can pick the right one according to his tendencies. Itunes technical support. Our submitted gathering of is just a phone way and accessible immediately relentless. Itunes customers can come to us to benefit answers for any of their issues including the ones referenced here under Itunes best without toll number, there are 4 outright ways to deal with associate with them.The accompanying most perfect way to deal with banter with their customer reinforce gathering, according .Ipad Support Avail Ipad Support To Quickly Resolve All Ipad Errors Independent Ipad Support Phone number for Ipad Help The line of tablet computer designed, developed and marketed by Apple Inc.
Oct 16, 2019 | Apple Computers & Internet
Amazon Prime rEfUnD conTacT pHoNe #{+1-85O-8I2-4OO9 how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Oct 16, 2019 | Amazon Computers & Internet
-\&;-TURBOTAX Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Turbotax USA phone number is ranked #2 out of 2 because 7,728 Turbotax USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Turbotax USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Turbotax USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Turbotax USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Turbotax USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Turbotax USA Calling Turbotax USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Turbotax USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Turbotax USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Turbotax USA's phone numbers against each other. Contacting Turbotax USA in General While I8OO8280294 is Turbotax USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Turbotax USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Turbotax USA.
Oct 16, 2019 | Best Computers & Internet
See all HP Compaq Business d530 Small Form Factor PC Questions
HP Compaq Business d530 Small Form Factor PC Desktop Logo
1,723 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
