Question about Garden
Where do i find a manual or a nielsen corp oregon chainsaw blade sharpener
Need a manual for chainsaw blade sharpener model number 011-68
  • 398 Answers
SOURCE: I NEEN A OWER MANUAL for a poulan chain saw 2150
its pretty easy to do with a file. first make sure you buy the right size file to fit right in the tooth. look closley at the chain and figure how to place the file on it. the point is to sharpen the side and top of the cutting part of the tooth .always file one way away from yourself. hold the file at an 45 DEGREE angle, and push forward. the trick is to push forward and up at the same time, and always go one direction. start on one side and mark your starting point with tape, go down one side then flip the saw and down the other. you dont have to push hard just enough to were you can see tiny metal fall off. lemme know if you have a problem
Posted on Mar 21, 2009
  • 597 Answers
SOURCE: black&decker ccs818 chainsaw
Each type of chain may be a little different but for the most part it's about 45 degrees for the teeth that have a square outside to topside angle and 35 to 40 for the rounded outside to topside teeth.
Posted on Jun 03, 2009
VtToolMan
  • 704 Answers
SOURCE: i need to know the right angle to sharpen my chainsaw
If your saw still has the original bar and chain, it was supplied with a .325" pitch chain and you'll need a 3/8" round file with a sharpening guide to properly sharpen it.
Here's a link to the Husqvarna site to the Rancher 455 models so you can select the correct manual to download, that matches your particular saw, based on the year of manufacture, etc.
There is some excellent information about maintaining your saw, along with a really good guide with step-by-step instructions for proper sharpening.
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=455&types=O
If you're having trouble figuring out the right manual for your saw, use the online Customer Support page and they'll reply.
Hope you find this Very Helpful - Best regards!
Posted on Aug 19, 2009
dontbother10
  • 2220 Answers
SOURCE: lost my manual for my poulan pro 255 chainsaw the
If looking for parts your OM is of little value. You can find an IPL (exploded parts list) here (only one PP255 listed):
http://www.ordertree.com/modelinfo/PWE/PP255-Gas-Saw/75.PP255-Gas-Saw.1.59.1.html
Rear vibration (isolation spring)s appear to be item 5 or 59 on the "Exterior Assembly" print.
Poulan replacement OM.
http://72.3.225.179/manuals/87722e.pdf
There is contact us number in the OM if you want to contact Poulan. HTH
Lou
Posted on Feb 15, 2010
Testimonial: "thank you very much for the information that you sent me. i spent two hours on a dial up modem trying to find the part and 20 seconds to read your rep"
agent91
  • 2100 Answers
SOURCE: what size file do i use for a Ryobi chainsaw model pcn4545
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Posted on Feb 25, 2010
AN INSTRUCTION MANUAL FOR OREGON 23820 CHAIN SAW SHARPENING GUIDE
any youtube media help at all
.tool explained
OREGON Chain Sharpening chainsawbars co uk using filing guide system
the manual is confusing more difficult when DYSLEXIC
Oregon chainsaw chain filing tool manual
Jun 16, 2016 | Garden
What do all the numbers mean on the chainsaw sharpener kits?
Not all chainsaws are the same size, the numbers that you see on the kits are the size of the blades on the saw. You have to make sure that the sharpener you get is the right size for your saw.
Sep 17, 2013 | Garden
Does the blade ever need to be sharpened or replaced?
A chain saw blade requires sharpening often. It can be in as little as 20 minutes if your cutting a very hard wood. Even less if you happen to allow the blade to be used in dirt.
Here is a video to help you use a "file guide" to sharpen your blade.
^^^-- note the videos on the right side of the video that is playing.
This is the most commonly available file guide:
Oregon Scientific Oregon 7/32" Chain Saw File Guide with File #25892
http://www.google.com/search?hl=en&safe=off&rls=com.microsoft%3Aen-ph&biw=1003&bih=587&tbm=shop&q=Oregon+25892&btnG=Search&aq=f&aqi=&aql=&oq=
Thanks for choosing FixYa,
Kelly
(Another video below)
Jun 12, 2011 | Remington Electric Chain Saw
Sharpening blade of chain saw
The blade needs sharpening when it stops cutting very well. Here is a website to tell you how to sharpen it...
http://www.ehow.com/video_4419332_sharpen-chainsaw-chain.html
May 11, 2010 | Garden
Looking for sharping stone from efco fl64 /8 chain
There are multiple chain sizes 1/8", 3/16", 1/4", 5/32", 7/32" and 3/8" chains so the /8 chain number has me guessing. After the qurestions below, here is my best guess.
Also is this for a chain grinder?" or
Are you looking of a hand held type stone?
Aluminum Oxide Chainsaw Sharpening Grinding Stone
or Ceramic stone?
I will assume that your looking for aluminum oxide stones at this time.
http://www.oregonchain.com/homeowner/products/accessories/replacement_stones.htm
This is wide selection of sharpening stones.
You can also use hand held chain sharpening files of the same size that have shapening angles marked on the file set fixture.
Hopefully you have a sharpening guide that will keep your angles correct while shapening.
A safety note: Improperly sharpened chainsaw blades can be very dangerous to the user.
Thanks for using FixYa.
Kelly
Mar 10, 2010 | Oregon Scientific Garden
I am also looking for a user's manual for the same chain saw sharpener. EFCO INDUSTRIES FL6
Here is a link to efcopower. Pretty good chainsaws; no chainsaw sharpeners!!!
http://www.efcopower.com/indexPri.jsp
Their parent company
emak Italy. No chainsaw sharpeners!!!
http://www.emakgroup.com/
Is there a tag that says Efco Industries?
I think this is an urban myth among chainsaw folk!!! Please do what can to stop this mis-information!!!
Tecomec chainsaw sharpeners (Italian subcontractor for Oregon)
http://www2.tecomec.it/database/tecomec/tecomec.nsf/prcat/AD47E80A73B834FBC1256E670057DEDA?OpenDocument
Click the appropriate model, at the bottom of the page is a pdf. There are both 240 & 120 VAC models, use care. HTH
Lou
Nov 13, 2009 | Garden
I need to know the right angle to sharpen my chainsaw
Aug 19, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Require a manual for an ''efco'' chain sharpener.
There are no "efco" chain sharpeners at Northern Tool or at efcopower.com. There is a Chinese made grinder with the Northern Tool name on it. It is a lessor quality copy of an Oregon model 511A. It is such a good copy that parts and the manuals are interchangable. The 511A manual can be downloaded here: http://www.oregonchain.com/pdf/accessories/511AManual_3Lang.pdf
Lou --> -->
Apr 04, 2009 | Northern Tool Garden
Garden Logo
511 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
