Question about Pioneer CDJ-500II CD Player
Pitch/Tempo control/fader problem
I have 2 off CDJ-500ii decks and both are now starting to fluctuate on the pitch/tempo control/fader to degree of shifting +/- .2 without touching it. Can a repair be done? If so, at a shop or can i repair myself? Or , Do i need to replace? Can i get replacements as they are now discontinued models? etc etc etc. Thanks
  • Colin Laycock Aug 10, 2007
    I will try the contact cleaner and let you know how I get on. Thanks.
You can buy a contact cleaner spray and spray inside the fader while moving the fader from -10 to +10. If the problem is dust or dirt this will fix it. If the problem presists, then go ahead and get a fader replacement.It's easy to replace ;-) Regards. DiMiS Greece.
Posted on Aug 10, 2007
I am having problems with the pitch on my mk 3 cdj, it doesnt seem to be working any more, The only way i can set my bpm now is by pressing the tempo reset button, Is this a common problem as i have never...
Hi, Possibly pitch slider at fault but would need to be inspect to be 100% sure. if you havent got your player repaired and you live in the uk then you can try this site. www.audiovisualservices.info
Hope this has helped you.
Thanks.
Jan 16, 2011 | Pioneer CDJ-1000 CD Player
My CDJ 1000 mk2 pitch control doesn't work and it doesn't regeister on the display, can you help??
The pitch faders do fail but usually they just become erratic rather than give up completely.
I think the most likley problem is a crack on the pitch circuit board or problems caused but liquid spilt into the pitch fader.
Aug 11, 2010 | Pioneer CDJ-1000 CD Player
A drunk guy throwed a little bit of beer on the cdj (it was REALY just a little bit) and it's having many problems now: FIRST: i can't eject or insert any cd's. I think it is Error 9101. Not sure because I...
If this was brought to me for repair the first thing I would do is completly strip the player to clean out any beer residue. This would involve washing all the plastic parts (top chassis, knobs, jog wheel parts etc etc) in warm soapy water. Any residue on the circuit boards is best cleaned off with a toothbrush and an alcohol based spray / liquid such as Isopropyl alcohol (if nothing else available metholated spirit will do but it tends to leave a purple residue itself).
Some spare parts may well be needed if, for instance the beer has got into the tack switches or pitch fader etc.
Error 9101 is stated as :-
Mechanical time out - Abnormality of disc loading mechanism
so the beer may well have got in the deck aswell but it could also be the electronics are confused causing the deck to do stange things thus generating the fault code - hard to say for sure without having the player on the workbence.
I hope this information helps.
Good source of spare parts :-
http://stores.ebay.co.uk/methleykev
email me on mail@technicsdjuk.com
Jul 04, 2010 | Pioneer CDJ-800 Turntable
The pitch slider suddenly wont go bellow 0.00, for
i had a similar problem i used a can of compressed air and sprayed the dust out from pitch control and it worked. the dust builds up static and interferes with signal> hope it helps
Nov 30, 2009 | Pioneer CDJ-1000 CD Player
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit board.it's a peace of **** to sort them.
if you help e-mail me djtatty@hotmail.com
Jul 20, 2009 | Technics SL-1200MK5 Turntable
How come my axis 9 cd players pitch control moves on its own?
i take it u know to press key when changing the tempo? if u press key it changes the tempo but keeps the pitch the same. i keep that on all the time. if i want to change the pick i hold key and press either + or -
Mar 22, 2009 | Nu Mark Numark Axis9 Table Top CD Player...
New pitch Control for pioneer cdj 500 mk 2
Enter your make and model in a search engine like google.
Put "parts" along with your search
Nov 13, 2008 | Pioneer CDJ-500II CD Player
Pioneer cdj pitch control
You have to properly calibrate your unit after any repairs. If you purchase the Service Manual for this unit, it will instruct you on how to accomplish this.
- Davis
DIGITAL ANALOG THERAPY
www.repairnyc.com
www.djproaudio.com
Apr 01, 2008 | Pioneer CDJ-1000MKII CD Player
Technics 1210 Mk 2 Pitch Fade Problems
You have to understand any sort of calibration meter will only tell you if the pitch control is faulty - or excessively too fast/too slow. If your units are just 'off' then that is a matter of a simple calibration of your pitch controls back to original factory specs. Also, just so you know, the pitch controls on the 1200s are not really calibrated when they leave the factory. They are basically installed, set a default setting, then shipped off. So, you'll often times have 2 turntables with sequential serial numbers, but they are both off.
Here is a tutorial on calibrating your unit back to original factory settings: TECHNICS SL1200MK2 / SL1210MK2 TURNTABLE PITCH CALIBRATION
You can also print this out and give it to the technician who serviced your units. Also ask him what kind of calibration meter, or unit did he use to test? Just curios.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians.
Dec 02, 2007 | Technics SL-1210 Turntable
Pioneer CDJ-500II CD Player Logo
243 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
