Question about Dryers
Hampton bay model ac552al
I purchased a house with 3 Hampton Bay Ceiling Fans with up and down lights all Model AC 552AL, SKU 836-374 TT YL. UPC code 18212045824. We only had 1 remote that matched one fan. I have since purchased 2 additional remotes for the pother 2 fans and have successfully changed the frequency to match one of the fans. I can't get the remote to work on the opther fan regardless of choosing switch 1,2,3 or 4 inside the remote. I'm guessing the receiver in the fan may be bad or is it possible it requires combination multiple switches chosen? I can't locate the receiver on the fan to see if there might be a setting there or possibly replace it. Where is the receiver located and is it replaceable or do you have other suggestions? The fan works and the lights are on but there is no way to change speed or turn off the lights. The serial# of the problem fan is 002300. Thanks
  • 178 Answers
SOURCE: Ceiling fan replacement parts
Here is the link for SOME parts for Minka Aire Fans. They don't necassarily need the model number, just the balde dimensions for replacement. Hope this helps you.
Posted on Mar 24, 2008
SOURCE: 3-speed switch replaced with hampton bay switch. Only low speed works.
The cause to the problem was replacing a HUNTER fan switch with a Hampton Bay switch. Before removing the old switch, I noted and marked the color and position of the 4 wires. I then duplicated the connections to the new switch.
But the wire positions of Hampton Bay vs Hunter are not identical, therefore 2 wires
were crossed.
The correct way is to note the color of the wires with the corresponding NUMBER
marked on the switches, then duplicate this on the new one.
Du-uh!
Posted on Jul 24, 2008
SOURCE: LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Posted on Feb 23, 2009
MNTECH
  • 1543 Answers
SOURCE: converting 3wire GE Dryer to 4Wire connection
Remove the wire or metal strap from the center terminal to the dryer frame. Put the white wire on the center terminal. Put the green wire on the dryer frame. Red to one outside terminal, black to the other.
Posted on Apr 16, 2009
  • 1810 Answers
SOURCE: Hampton Bay Ceiling fan will not come on
greetings home electrition
it's most likely the switch has failed
but on rare ocation the switch comes un wired
also somtimes the switches stick they stick in the on or off position
try pulling the chain and listen for the usual click if it aint there then the switch is pooch if click is there start look at the wires failing that replace the switch
there cheep 2-5.00
Posted on Jul 29, 2009
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
http://www.homedepot.com/b/Lighting-Ceiling-Fans-Ceiling-Fans-Accessories-Ceiling-Fan-Parts-Remote-Wall-Controls/Hampton-Bay/N-5yc1vZbvmuZp4
Apr 03, 2017 | Hampton Bay Dryers
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
Need to purchase fly wheel for Hampton Bay five blade fan 1988 model. Where could I?
I didn't know a low end fan had a flywheel. Can you send or post a pic? fanman9952@aol.com
Oct 17, 2014 | Dryers
Looking for hampton bay sibley 52 in vintage brass ceiling fan 46796
Have Hampton Bay Sibley 52" Ceiling Fan brand new in box for sale. ski 082392467968 vintage brass finish w/ single beige linen globe.
coronaxtr@hotmail.com
Jun 25, 2012 | Dryers
Do you have free manuals for a hampton bay ceiling fan model 52 rdt?
http://www.homedepot.com/catalog/pdfimages/c6/c640c29e-5efd-4045-be74-016e88d7e04b.pdf
According to Home Depot this is the Hampton Bay manual for that model number.
Indicated here: http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10051&catalogId=10053&productId=100032172&R=100032172
Excerpt:
  • MFG Brand Name : Hampton Bay
  • MFG Model # : HD302243
  • MFG Part # : YG092-VPW
Jun 05, 2011 | Hampton Bay YG092-VPW 52'' Preston Vintage...
Looking for an owners manual for a Hampton Bay Huntington III ceiling fan
Contact "King of Fans" (kingoffans.com) in Ft. Lauderdale at 800-330-3267. They made or make Hampton Bay fans. I just ordered an arm for mine. Have your UPC number handy.
Feb 16, 2011 | Hampton Bay 24750 Huntington III Ceiling...
Missing remote for a clarington ceiling fan model sku 507090 .serial number 8239271605. home number 450 969 2309
Feb 13, 2011 | Hampton Bay 24002 Ceiling Fan
I HAVE A HAMPTON BAY MODEL AC-418 CEILING FAN. IT
Your issue is most likely a faulty speed control. The part is integral to the remote receiver in the fan housing. You can purchase spare parts for this fan through Home Depot (Hampton Bay) Service at 800-654-0688.
The fan unit itself is manufactured by AirCool 800-896-4908
May 10, 2010 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Are you talking about a Hampton Bay ceiling fan product. Is there a label stick attached to the top main housing unit that indicates the model & UPC #. If it;s a Hampton Bay...
There is a a major ceiling fan manufacturer in Fort Lauderdale FL called King of Fans (website: kingoffans.com) that deals strictly with Hampton Bay ceiling fans & parts. They are the Home Depot distributor for Hampton Bay ceiling fans. Their number is 1-800-330-3267. There is also a 1-877-527-0313 number for Hampton Bay products other than ceiling fans...
Nov 01, 2008 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay Fan 55295 remote control
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30-Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan you will be able to get to the needed additional information.
After downloading and reviewing my fan's Owner's Guide, and reviewing the online FAQs, I called 1-800-330-3267, concisely described the problem, and ordered the parts needed with only the fan name and SKU.
I and am about to order more parts after suffering a power surge (The needed info was in the FAQs). My experience is great customer service and speedy delivery of the needed parts.
One of their FAQ's answers the question:
Where can I get parts for my ceiling fan?
You may call customer service at 1-800-330-3267 on Monday through Friday EST. When you call please have your UPC code available. If you do not have your owners manual, you may look on the top of the fan where you will see a silver or gold sticker. There you will find a UL number beginning with the letter E and located under the UL number is the UPC code. The UPC code consists of 12 numerical digits. From that information, the customer service representative will be able to determine if you are calling the correct company and determine the make and model of your product. If it is determined you are calling the wrong company, you will be given the correct number to call.
Jan 25, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Dryers Logo
176 people viewed this question
Top Dryers Experts
