Question about HP DeskJet Office Equipment & Supplies
My hp officejet 4620 is only printing gridlines from my bank statement
benatl26
SOURCE: Right Margin Does Not Print
This one work for me...on top left of the page click on file then click print. A box print with option opens...... click options then select or put a check on left bottom box that says print all linked documents....good luck!
2nd option or
Last option and 100% will print the entire page even allows you to select what you want to print inside the page. Its called webcollect and here is the link.......http://www.web-collect.co.uk/
Posted on Mar 29, 2008
hemantraj
  • 638 Answers
SOURCE: HP Officejet All-in-One Printer
remove all the wires connected to the printer from its back.also wait for 5 minutes.then delete any pending printouts in the printque of the printer in your pc.shut down the pc.connect the printer to the pc.ON the printer.then ON the pc and then try printing it should work.
thanks.
Posted on Nov 15, 2008
yooperbud
  • 8637 Answers
SOURCE: Dell P1500 Printer does not print Mriscroft Calendar gridlines
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
rulds2008
  • 3866 Answers
SOURCE: My HP PSC 950 prints anything from the Inernet too
Browser printing option is set to print small you need to check that and make sure you using landscape.. There should be no other reason why so check those landscaping options- thanks and please rate acordenly anything above a thanks for trying would be pleasureable..
Posted on May 15, 2009
prashant2012
  • 1127 Answers
SOURCE: PRINTING IS LIGHT AND NOT
Hi
check your printer cartridge level its very low, so refill the cartridge or purchase new one,
Posted on Jun 23, 2011
Hp officejet 4620 does not print with starter cartridge
If printer is in warranty, demand for replacement.
1. Check ink levels in printer..if levels are showing, take out all ink cartridges refill them.
If levels are zero, go for new cartridges.
2. If ink level are showing in printer & physically cartridges having ink, then problem with print head, try to clean the clogged nozzles.
Nov 16, 2014 | HP Officejet 4620 e-All-in-One Printer,...
How do i remove the print head from hp office jet 4620
remove all the inks and look for a release lever might be grey in color or black lift the lever and remove/lift the print head assembly from printer... your inks sit directly on top of the print head assembly
May 03, 2014 | HP Officejet 4620 e-All-in-One Printer,...
HP Officejet 4620 not printing even with full cartridges
the printer only follows instructions from the computer
If you get weird things , the driver is suspect for the printer
Jan 29, 2018 | HP Officejet 4620 Wireless Multifunction...
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
Hp 4620 printer doesn't print black ink
i have same problem and have tried everything suggested on HP website. I can print in color but not black and white
Nov 08, 2012 | HP Officejet 4620 All in One
Blurred officejet 4620 photo
Have you checked to be sure that -
  • you've designated the paper type as one of the photo type papers?
  • you've designated the print quality as either Normal or Best (NOT Draft or Quick or similar low-quality print)?
  • you're using one of the photo-type papers?
  • none of the ink cartridges is low on ink?
Sep 17, 2012 | HP Officejet 4620 All in One - CZ152AB1H
Can't print line
Depending on what version of Excel you are using try the following:
The lines are called gridlines
  1. Click the worksheet.
  2. On the File menu, click Page Setup, and then click the Sheet tab.
  3. Select the Gridlines check box.
Note Large worksheets print faster if you do not select the Gridlines check box.
Please rate this solution...Thanks
Mar 24, 2009 | HP Officejet 5610 All-In-One InkJet...
27 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
