Question about Onan Microquiet RV Generator 4000 Gasoline 4.0 Kyfa/26100
Onan bfa 4.0 generator
This unit is only putting out 60volts. do you an idea as to the cause
    Prodigy:
    An expert who has answered 500 questions.
  • Onan Expert
  • 573 Answers
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Posted on Feb 19, 2015
How to clear the code fault on my Onan 4000 generator. What causes a fault & why???
what model is it KY KV need that and Spec. If it blinks 3 times it indicates a lower service fault. While blinking hit the stop button 3 times fast, then read the code. It will blink, pause then blink again and repeat. What is that code and I can help you. IE 4 blinks pause and 3 indicates code 43
Nov 13, 2014 | Watts Onan Portable Generator - 4000 ,...
Free onan generator manual
i have a onan model5.5 HGJAB-1038C GENERATOR IT SHOWS CODE 14 IT WILL START FOR 15 SECONDS AND WILL STOP -- I HAVE REPLACED THE FILTER, NEW FUEL PUMP. NEW SPARK PLUGS- CLEANED CARB AND STILL NOTHING I AM IN MEXICO AND NO SERVICE PEOPLE I NEED A SERVICE MANUEL FOR THIS UNIT--THANKYOU PLEASE
Jan 12, 2014 | Computers & Internet
Onan Propane Generator Problems
Is the generator coming up to proper speed? A cycles (hertz) (should be 60 in USA) meter will tell.
If it is up to speed, see if a UPS unit is made powerful enough to power the microwave. That will handle the initial starting load from the microwave.
UPS units are handy to power stuff while you are getting the gen going.
Nov 28, 2013 | Onan MicroLite Generator, 2500 Watts / LP...
Onan generator fuel pump
Did you change the pump with the correct Onan pump, these are special low pressure pumps, and automotive pump will not work and can cause dangerous flooding and carb issues.
Jun 24, 2013 | Electrical Supplies
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan 4 ky generator quits when a/c is turned on? Has no other load on it.
Is your generator 4 kW or 4000 Model 5500.
If 5500 as on the picture over your question the reason may be short in the receptacles or low voltage/ rpm.
If 4 kW MicroQuiet, there the reasons may be too much, that you will nead a troubleshooting manual.
Jun 14, 2010 | Watts Onan Portable Generator - 4000 ,...
I have a 1999 Onan Generator start/stall issue
Check your oil level. The unit will stay running as long as you have the switch depressed. When you get enough oil pressure a switch closes & keeps it running.
Aug 16, 2009 | Sport & Outdoor - Others
6.5 onan emmerald 3 NEH bad fuel pump.
As long as the pump puts out 3.5psi to the carb, it should do the job.
Mar 23, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan generator MODEL 7NHM FA 26106 F
4psi is the correct parameter for this unit.
Mar 01, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan Microquiet RV Generator 4000 Gasoline 4.0 Kyfa/26100 Logo
109 people viewed this question
Top Onan Electrical Supplies Experts
Lawrence Oravetz
Jeff Hogancamp
Jeff Hogancamp
Are you an Onan Electrical Supply Expert? Answer questions, earn points and help others
