Question about HP Compaq Presario SR2050NX PC Desktop
Network controller driver lan1 usb12 - HP Compaq Presario SR2050NX PC Desktop
The only lights on are power and lan1 on sending unit, no internet access
1.Check all your cables for faults.
2.Check that you have the drivers for your internet connection installed on your laptop,desktop. If not re-install.
3.Try re-setting your router.
Aug 02, 2014 | Ubiquiti Nanostation LOCO M5 Outdoor MIMO...
Router modem-CAT5 adaptor
does this router have a lan1 lan2 lan3 lan4 ports ?
the adsl port may be for a phone line so you may need to turn off the ADSL functions in the Huawei Echolife HG520s router . Turn off the DHCP server and then plug connect lan1 to your office network. Change the ip address to be unique in your office network ip network range.
maybe 192.168.0.2 if office router is 192.168.0.1 subnet mask made the same .
Jan 30, 2018 | Computers & Internet
Hai, Good Afternoon, how can i configure Local network through ADSL router to Switch (d-link DE-816TP)
Hi...
It's simple...
Reset it to the factory defaults; Connect an ethernet cable from the modem/router to the first LAN input (LAN1) in the D-Link device; Connect computers/any other device to any of the rest LAN inputs...
Done! :)
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Apr 06, 2011 | D-Link DE 816TP (DE-816TP) Networking Hub
How do you connect D-Link DIR-655 router if using an Apple computer? The Apple computer is currently connected to the modem. I have purchased a Dell laptop PC and want the PC to be connected on a...
1. Router's LAN1 connect to Apple through Ethernet cable.
2. Open your Dell Laptop's wireless network connection and search the network and then you can connect your Dell laptop to your router through wireless connectin.
Apr 02, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Can't Connect more then 2 devices, on my Linksys Wireless Broadband N router. Called Linksys tech support not helpful, the other devices are coming up with Parental Controls.
Can you explain about your network diagram, what type of connectivity you looking????
or you can connect your devices as per below:
1. ISP cable -> Router1's Broadband port
2. Router1's LAN1 -> Router2's Broadband port
3. Router1's LAN2 -> Router3's Broadband port
Mar 31, 2010 | Linksys Wireless-G Broadband Router
Can't access adminpage of the router from the 1st lan
you can use ethernet cable, or you can use the wireless.
search for the wireless network and connect your pc to that wireless network. or simply connect an ethernet cable to your pc and connect other end to the Linksys WRT54GL .
open an internet explorer (or whatever you use) type ip address.
Dec 17, 2008 | Computers & Internet
How do i connect up my router
To physically install the router
Step 1: Connect the power adapter Connect the power adapter to the router and plug it into an electrical outlet not controlled by a wall switch.
Step 2: Connect the router to the computer Disconnect the ethernet cable that is connecting the broadband modem to the network adapter in the computer. Connect the ethernet adapter in the computer to one of the LAN ports on the router.
Step 3: Connect the router to the modem Connect the ethernet port on your broadband modem to the WAN port on the router.
Step 4: Check link lights and connections
Check the front of the router to make sure the Power, WAN and LAN1 lights are on.
Jun 29, 2008 | Computers & Internet
HP Compaq Presario SR2050NX  PC Desktop Logo
166 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
