Question about Technics SL-1200MK2 Turntable
Replace Power Cord - Technics 1200 MK2
I need to replace the power cord on my Technics 1200 MK2...I already know how to disassemble it and I know the new cord needs to be soldered on...but not sure which connection on the circuit board is the positive, and which is the negative? It is not labeled...
    Habit-Forming:
    New Friend:
  • 12 Answers
As long as the only thing damaged is the power cord, this should be easy. You said that you needed to know how to tell which side is positive and which is negative? The power cord carries alternating current not direct current. So in this case, polarity really isn't important. The same applies to the two yellow wires supplying the main motor board. They are A/C too. As long as the replacement cord you use is of equal or higher power handeling, and you make sure your connections are solid, it will work fine regardless of polarity. Just be sure the only problem is the cord. Check this link to be sure. Good luck, EW.
This link is a must have for anybody diagnosing a problem with a SL1200/1210. Take a look:
http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf http://www.deckdoctor.com.au/TECHNIC%20SL1200%20PCB.pdf
Posted on Jan 01, 2015
    Problem Solver:
  • 5 Answers
It's an ac cord. there is no positive and negative. the solid black side is "hot" and the ribbed or striped side is "neutral".
Posted on Dec 19, 2013
4 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: Technics SL-1200MK2 Turntable i need to replace the on off switch on a mk2 technics 1200 any
The part is located HERE - but you will have to take apart your turntable from the bottom in order to replace it. It's not very hard, but if your not mechanically inclined, I would not suggest doing it, as you could cause more damage.
- OPTiC
The 1200s Expert
www.1200s.com
Posted on Sep 08, 2008
Grubhead
  • 5455 Answers
SOURCE: technics sl 1200 MK2
Yes and the good news is the 2SD1265 will cost you under a few pounds including P&P from Grandata Limited.
www.grandata,co.uk
Posted on Apr 09, 2010
  • 135 Answers
SOURCE: My technics 1200 hums when connected to the amp
Is the ground wire from the deck connected to the mixer?.
If everything is connected ok then the ground wire or phono cord could be faulty - look here for replacements :-
http://stores.ebay.co.uk/methleykev
Could also be a "ground loop" - try a ground loop isolator.
Posted on Jul 13, 2010
Need to replace power cord - Technics 1200 MK2
Apr 28, 2013 | Technics SL-1200MK2 Turntable
My technics 1200 hums when connected to the amp even when the power cord is disconnected.
Jun 26, 2010 | Technics SL-1200 Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
styluscity@gmail.com
May 10, 2010 | Technics SL-1200 Turntable
Technics 1200, no sound out right speaker
And it will be. I can almost steak my life on it. Easy to replace. Most djs had to already. Most off us went to Radio Shack and bought the 6 foot gold RCA's and cut them in half for both decks. Its not that hard to do. Any problems message me.
Oct 29, 2009 | Technics SL-1200MK2 Turntable
Magellan 1200 RoadMate Unit no longer turns on
That means that the battery inside the Magellan must be replaced.
There is need to disassemble the unit to replace the internal battery.
May 21, 2009 | PSC Magellen SL (554030-20150-020)
Stopped working
No! I meant trying another wall outlet. If you do not have a meter to check the power then try another plug. The motor will usually have some hum or noise if there is power to the motor. Steve
Feb 08, 2009 | Technics SL-1200 Turntable
Technics 1200 turntable - no power Musical Fidelity AMP - no power
Technics 1200 - if the mains cord connectors and fuses are ok - it could be the power switch - when you rotate the switch do any lights come on? If it is just no rotation of the turntable platter then it could be the motor controller IC.
There is an internal regulator - often the associated zener and transistor fail.
Please rate this as a genuine cure - I know these inside out and with a bit more information I can give you a solution.
Mar 19, 2008 | Audio Players & Recorders
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1200MK2 Turntable Logo
353 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
