Question about Symbol PPT 8800 Portable Terminal
Dialing through the modem
I'm using the 8800 for a business customer, and dialing through the modem works just fine on the direct outside phone line. However, when a 9 needs to be dialed to get an outside line, I can't connect to the modem. I have tried putting a 9 and commas in front of the phone number as well as using the dialing rules to dial 9 first. Neither works. Am I missing something?
  • 12,061 Answers
Ok sometimes PABX systems just don't seem to play well with modems... as a thought put a couple of Commas, a "Pause" B4, AND AFTER ya try to dial the 9, IE: ,,9, As sometime it takes a while for the PABX to "Latch on" to the DTMF tones. Thats all I can think of really.
Posted on Aug 08, 2007
SOURCE:
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
My verifone will not dial out. I have used several lines and even took it to the central office and connected directly to the analog line there. When i listen in monitor with a handtest set i do not hear...
The modem in the terminal is defective.
Confirm by having the terminal dial into your direct extension, if confirmed that the modem is not dialing out, like you did them the terminal will require service.
WE CAN HELP CALL US @ 775- 358-2922 : - )
Aug 18, 2011 | VeriFone Omni 3700
Some phone calls cant go throw
I assume that this is a home phone issue. If so, it is possible that it is setup to dial an outside number before dialing the number that you input (like at work we dial a 7 before dialing our customers number). This will make your calls have an extra number at the beginning if it connects directly to an outside line.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
Jun 10, 2009 | Panasonic Lands Phones
Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
http://www.allnet-italia.it/img/speciali/pdf/777702433.pdf
if you need more call me at 804-372-RROD
May 03, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Cannot fax
Is thi sin an office?
Are you using a direct outside line or is it an office extension?
Your office extension may have restrictions on it and you would need to remove those.
I would confrim the numbers are fax numbers and that that line is ok by:
  • Dialing those fax numbers from a working phone line other than the fax machine
  • Unplug the fax and plug in a regular phone in the same line and see if you can dial out and then try those fax numbers again.
If the numbers work from a normal phone but not the fax line, then I would check that line for restrictions.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Acer 5720
hmm..well..this maybe as simple as the phone number setting in your dial up application..do you have call waiting or voicemail on that line? You may need to set the phone dialer to compensate for that issue.
Apr 30, 2008 | Acer Aspire 5500 5570-2609 Laptop
Need to install a modem on a Quick Eagle 4200T CSU
C-NOS:
Basically the modem has to dial in first to give you connection, One end goes to the Phone wall socket and the other end to your computer.
-Now in your case I am sure that your router is a DSL router meaning have no capability of dialing on command from the external modem.
-Nowadays VOIP built in routers are much more capable of dialing numbers directly.
-Old dialing modems should be connected directly from computer to the wall jack (phone lines).
Hope that helped!
Dec 10, 2007 | Computers & Internet
No longer dialing Lond Distance
If your modem can fax a local number or dial-up an Internet Service Provider in your Local Area then your Internal Modem is just fine. Check if the configuration of your Modem to access outside long-distance number. Go to your Control Panel-Open Phone & Modem Options-Dialing Rules (Tab)- then click on EDIT Button. You can enter the number needed to have a long distance dialing. If you don't know the number needed for long-distance dialing then ask your Local Phone Service Provider.
Apr 04, 2007 | Smartlink (I56KSPF00) Modem
Symbol PPT 8800 Portable Terminal Logo
96 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
