Question about Sanyo 09KHS51 Ductless Mini Split Air Conditioner
BIP, FLOOR AIR CONDITONER, model: MOB12KR-342
Model: MOB12KR-342, NEEDS NEW BLOWER FAN.
How to fix a air conditon
Clean air filter?,. Coil air filter protects clean?,. Wash outside coil,. Is blower fan and outside fan up to speed,. If all this is true the. Freon related most likely
May 29, 2016 | Honeywell Heating & Cooling
Heating and air conditoner in jeep liberty
I had the same problem with my Jeep. The load resister in the blower air stream failed and caused the blower motor to have a heavier electrical draw than the wires were designed to carry and as a result it overheated the blower switch and attached plug. I advise you look at the back of the switch and if it shows signs of overheating, get the blower motor looked at by a qualified mechanic.
The switch costs more than the blower assembly.
Aug 16, 2013 | Heating & Cooling
Hot air through floor in 99 Suburban when blower is switched off
I the short answer is yes. The truck has a flow-thru vent feature as does most GM products. When the fan switch is off the outside air would flow into the truck.
I thought you could still direct the air by way of the control panel, but by the wiring diagram it looks like everything is disabled when the fan switch is in the off position.
Aug 24, 2012 | Chevrolet Cars & Trucks
Reverse rotatin on fan motor aire flo air conditoning model #20402077insol knew capasitor 3 tipe capasitor capasitor /hern/fan/c/
When the capacitor goes bad it can cause the fan motor to run backwards, the capacitor needs replaced.
Sep 24, 2011 | Carrier 38CKC036 Air Conditioner
Mob12kr-342--compressor shakes and rattles constantly
Check compressor mounting bolts, located at base of compressor, also make sure both the evaporator and condenser coils are clean, if dirty compressor could be starting under high head pressure, Good luck.
Mar 04, 2010 | Heating & Cooling
When I turn on the air conditoner or heater the fan motor makes a loud humming sound
replace the blower motor and resister it is ur speeds and when blower is resisting it will load it down and make it go out shortley
Jul 03, 2009 | 2003 Honda Pilot
Hyndai Sonata air conditoning blower only works on high
I agree with 'motgor1258'... replace the blower resistor (it's actually a power transistor).
Jun 19, 2009 | Hyundai Motor 2004 Sonata
FAN FOR HEATER/AIR CONDITONER SOME TIME WORKES AND SOMETIME DOSEN'T
check your connection at your blower motor and fan blower resisitor common problem
Aug 01, 2008 | 1993 Ford Ranger SuperCab
Sanyo 09KHS51 Ductless Mini Split Air Conditioner Logo
26 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
