Ariston aml 81 - Washing Machines
  • 1462 Answers
SOURCE: Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Posted on Jun 26, 2008
  • 8404 Answers
SOURCE: i am need the service
look here: http://manuals-market.com/
Posted on Mar 11, 2010
ginko
  • 19396 Answers
SOURCE: My Ariston AML 125 dosen't
Hi.
If the water is cold, check the inlet hose and the hot inlet in the dual inlet valve connected to the hose. If there is no hot water the cycle will not progress, and that may be related to the drain problem.
If the machine does not drain even with hot water, check the thermostat and the pressure switch. The thermostat decides when to open and close the hot inlet, moving forward with cycle when temperature is met. The pressure switch determines among other things when to start and stop drain pump.
The thermostat is tested reading Ohms, multimeter set on impedance must read low or no impedance at room temperature on thermistor contacts. The pressure switch is replaced if there is a drain problem and the rest does not help. This part is more difficult to test.
About the drain problem, check first drain lines, drain well and drain ose at the back.
As first thing call Ariston at the number listed on the owners manual and check warranty status.
Posted on Sep 15, 2010
taran_2005
  • 10515 Answers
SOURCE: looking for user manual for
You could download the manual from :-
http://safemanuals.com/user-guide-instructions-owner-manual/HOTPOINT-ARISTON/AML%20125-_M
Click on download the complete user guide. It would direct you to a new page.Rate the questions.Once done, a link for ' download ' would appear. Save the manual on the desktop.You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 21, 2011
  • 6277 Answers
SOURCE: i have a Ariston AML
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 04, 2011
Hi there I need the manual for AUXL105
Do you mean the Ariston AVXL 105? Manual Lib has the manual here: http://www.manualslib.com/products/Ariston-Avxl-105-3182207.html . The English part of the manual starts on page 13. The section on the programs is on page 18.
I hope this helps.
(The link: http://www.manualslib.com/manual/644893/Ariston-Aml-119.html#product-AVXL%20105 has the link to download the manual.)
Mar 02, 2015 | Washing Machines
Users manual
I found it, but there doesn't seem to be a way to link you to it. Here is where and how i found it. Go to google: type in search bar..." aml 125 " without the quotes, hit enter. On the first page of results scroll down to site that says "mypdfmanuals.com..." click on it. You will immediately start downloading a file. Once it is downloaded at the end of it is another link for your manual. I got warning messages that it's the type of file that can harm my computer (because it's PDF.) Click Disregard if to get the files. You may not get the warning unless using Chrome or Firefox. I don't know. But the file is ok. Hope this helps. Let me know if my instructions are confusing.
Jan 06, 2013 | Washing Machines
Where can i download instructions in english for a Ariston ARML125
HI JENIFER, I FIND A SOLUTION FOR YOUR QUERY. THE MANUAL FOR ARISTON ARML 125 IN ENGLISH IS AVAILABLE AT www.cintelcorp.net/ariston-aml-125-manual
Nov 03, 2011 | Washing Machines
Hi there, i have just moved into a flat and there is the ariston aml 125 washing and dryer and ihave no idea how to use it. all the soap powder sold in nz is top loader soap powder, is this ok to use in a...
Enter this URL into your web browser and you will be able to download the full manual.
http://safemanuals.com/314159.php?k=3c09a0dae46be7bd02298add3193e78a&ID=433640&q=HOTPOINT-ARISTON%20AML%20125
Jan 26, 2011 | Washing Machines
Looking for user manual for ariston AML 125 in english
Hope i helped you.
Jan 21, 2011 | Ariston Technologies AW125NA 13 lbs. Load...
Jun 26, 2008 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
