Question about Coffee Makers & Espresso Machines
Delonghi ec9 no noise no steam milk
SOURCE: steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Posted on Jul 05, 2008
mattofilms
  • 110 Answers
SOURCE: my delonghi magnifica is having a problem with
There are 'o' rings on the pipes (on machine - not milk container) where the milk container fits into. replace or clean them - should work like new.
Posted on Jul 02, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
SOURCE: There is no milk coming out of the frothing part
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
Posted on Jun 21, 2010
  • 7 Answers
SOURCE: Delonghi Rialto 4500. The milk doesn't go trough,
I fixed this problem on my Magnifica by gently scraping the scale away from the inside of the coupling (clearing the hole of scale and debris)
Posted on Aug 07, 2010
Coffee comes out fine, wont deliver milk or hot water from spout
Sounds like milk steam apparatus is clogged. Try to disassemble this portion and clean thoroughly. Descaling will not help this section.
May 04, 2016 | DeLonghi Magnifica Coffee Makers &...
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi EN720 milk won't flow properly.
replace o ring ,,, descale ,,, disasemble ,, clean ..
Dec 14, 2013 | DeLonghi Coffee Makers & Espresso Machines
Coffee maker not frothing milk
The tube on the "ball assembly" which connects to the "milk" tank may be missing an O-ring. If this O-ring is missing, the steam will only siphon a little bit of milk because there is no seal. If it is working properly, the siphon can fill be expected to fill a cup in about 30 -60 seconds.
May 19, 2012 | DeLonghi EC Coffee Makers & Espresso...
I have just bought a delonghi ec220cd coffee maker - a replacement for the delonghi ec270 which started to leak badly. However, the milk doesn't seem to want to froth - just wet and may as well just pour...
Try removing the plastic steaming sleeve and just use the stainless pipe. Keep the pipe just below the surface to make the ffroth, then go lower to heat the milk to a max of 165F.
Apr 27, 2011 | Coffee Makers & Espresso Machines
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
