Hott mu730 - Computers & Internet
Hi my name is Tommy Id Like to know how to fix file system error on HOTT MU723. please help!!, Tommy
Let's start from the star: what's supposed to be a
HOTT MU723? Is it a "cheapo" chinese mp3 player? If it is an mp3 player and you've got a file system error, open it in your computer and, psesuming it's Removable Drive E: try to repair it with chkdsk E: /F
If cna't, try to format it to FAT 32, though I don't know what might happen after that.
If no way to format it so be prepared to worst: you lost your mp3
May 05, 2015 | Audio Players & Recorders
Hott mu730
Question posted under water heaters.
Do you have water heater?
mu730 appears to be a mp3 player. Buy another one if it's broken.
Jun 19, 2013 | Water Heaters
Newly installed Hott Rod in 6 gal RV water heater only heats to lukewarm. Has been on for 12 hours. Outside temperature is 60 degrees
Hott rod is 120Volt AC.
Check voltage supply for undervoltage, or reversed polarity, or tripped breaker.
Check that electric thermostat is set to 120 degrees.
Rotate thermostat temperature adjustment back and forth and see if you can hear water heater working.
Thermostats can be bad, or stick.
Check the ECO red reset button is not tripped out.
If tank was not full of water before power was applied, the element will instantly burn out.
Use continuity tester across bare element screws to see if element is good. Or use multimeter and test across bare element screws shows 29 ohm for 6 gallon, 18 ohms for 10 gallon.
More resources at Hott Rod, for troubleshoot and contact.
http://www.hottrod.net/hott_rod_troubleshooting.asp
Oct 31, 2012 | Camco Hott Rod RV/Camper 6 Gallon Water...
How do you turn down the volume on the Hott MP3 player?
hold volume button down util the icon turns red then adjust volume with right arrow for up and left for down. when icon goes back to black it should have adjusted to the volume. Also the volume is listed numericly the higher the number the louder it gets.
Jan 12, 2011 | Audio Players & Recorders
Just installed hott rod to camper and it keeps blowing fuses what's wrong
A six gallon universal style hott rod, is supposed to draw only 4 amps when heating. What you need to do is double check any other items running on that same circuit. Not uncommon for people to plug it in to outside GFI and then find out that GFI protected receptacle near sink inside is on same circuit, and they are using that for coffee maker, or hot plate etc, which will in most cases overload the circuit.
Shut that circuit breaker off, and see what else isn't working then do an amperage draw calculation to see if you may be overloading it. If no chance of overload, then you may want to re-check how you wired it in case of a short, or loose connection. If all that checks out good, then I'd look at the hott rod itself as the culprit.
Dec 11, 2010 | Element Hott Rod Water Heater - For 6...
I need an instruction manual for a HOTT personal media player
need help my hott player keeps saying file error dont know wat to do
Nov 30, 2010 | Audio Players & Recorders
We bought a hott digital video player Mp4 MU763 and need to know what battery charger to buy for it
Hott MP4 MU763
I keep getting error message:
Windows cannot acess the specified device, path, or file. You may not have the appropriate permissions to access the item.
I have tried to turn it on, no screen. I do however, have a file on the hard drive which allows me to see what is on the device. Can't access device screen or contents. ???
Jun 24, 2010 | Audiovox MP4128 MP3 Player
89 jeep pick up
what you have too do is heat the truck up and as the truck is warm take the small hose off the head and take the cap off the water bottle on the side wram engine!!! not hott!!! let the water and antifreeze come out of the small hole it needs too be bleed from the replace hose back and it should be fine warm moter not hott!!
Oct 16, 2008 | 1990 Jeep Cherokee Limited
A/C JUST blows hott
a/c pressure .whats pressure? how much freon did you add?
Jul 12, 2008 | 1999 Oldsmobile Intrigue
Speedstream 6520 wireless gateway not working
I deal with these routers on a daily basis w/ Frontier. Likley the radio is getting hott and its starting to burn out.. Put your hand on the radio, see if its running rather hott. If it is, unplugg it for an hour. If your a frontier customer, call tech support, get it replaced!
Nov 11, 2007 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
