Vaatwasser type ADG9527 stopt en geeft F2 als teken
5 Suggested Answers
  • 18 Answers
SOURCE: zoek storings code f4 van gsfp3988
F4 is a drain pump problem, possibly bad connection on pcb
Posted on Jul 12, 2007
SOURCE: Bij aanvang van printen of kopi?ren stopt hij en de spanning valt
hoi , ik denk ook dat dat je printer kapot is want als alles gewoon werkt maar het wil niet printen dat kan niet goed zijn ik hoop dat je garantie er op hebt dan gewoon terug brengen en laten repareren
Posted on Jan 03, 2009
SOURCE: ADAPTIVE LIGHT GEEFT FOUT AAN LINKSVOOR EN ALLES
garage lost alles op
Posted on Jan 18, 2010
bronk50
  • 27725 Answers
SOURCE: a8n32-sli stopt na 10 seconden
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps
Posted on Jun 03, 2012
Mijn vraag is ik heb een Philips CDR 560 cd recorder alles werkt maar de VU meter geeft geen geluid signaal aan en er komt ook geen geluid uit de cd recorder als ik een cd wil afspelen terwijl de...
typically english is the prefered language to seek assistance. By submitting your query in non-english, you have reduced the potential for help by 800%
Oct 26, 2014 | Office Equipment & Supplies
Gaarne toezending activeringscode
Cees, Deze site probeert mensen te helpen met technische vragen. Daarvoor is het belangrijk, dat er een duidelijke vraag wordt gesteld. Ik denk dat het voor jou niet moeilijk is om te zien welke GPS je hebt, maar voor ons is het een compleet raadsel.
Mogelijk heb je een apparaat gekocht, dat je na aankoop moet activeren, maar dat moet je dan toch echt doen op de site die hoort bij het merk dat je hebt gekocht. Meesal staat het gewoon op de doos of in het handboek in de doos. Met site naam en wat je allemaal moet invullen voor de activering.
Als het niet om een nieuwe GPS gaat, maar als je zelf een kaart ergens vandaan hebt gehaald, moet je echt andere wegen bewandelen om achter de activering te komen. Daar zijn vooral in Nederland veel sites actief, die, weliswaar tegen een geringe vergoeding, alle mogelijkheden ter beschikking stellen om in oudere apparaten nieuwere kaarten actief te maken. Maar het past niet op deze site daar al teveel over te zeggen. Dus zelf even google gebruike.
Als je een technische vraag hebt, is het handig als je zoveel mogelijk gegevens geeft over het apparaat, het operating systeem en over de situatie waarin het is, alsmede hoe het in die status of situatie is gekomen.
apparaat : merk en model
OS bijvoorbeeld Windows XP of Mac OS 9.6 Of als het om een GPS gaat, bijvoorbeeld welke boot loader en welk systeem erop draait.
Sorry dat er na zo'n lang verhaal geen oplossing is, maar ik heb goede hoop als je iets technisch hebt we je wel kunnen helpen.
Oct 01, 2014 | GPS
Klep is geopend
Het probleem zou te wijten zijn aan een vastgelopen printer te dekken sensor of als gevolg van de cartridges in de drager. Volg de onderstaande stappen te identificeren en op te lossen:
1. Zorg ervoor dat de printer is ingeschakeld. 2. Open de klep van de printer. De cartridgehouder wordt beweegt en stopt bij de laadpositie, tenzij de All-in-One is bezig. 3. Verwijder beide cartridges uit de drager. 4. Sluit de printer te dekken. 5. Loskoppelen en opnieuw aansluiten van de printer in het stopcontact steken om het te resetten. 6. Wanneer de printer wordt ingeschakeld, plaatst u een cartridge eerste. 7. Sluit de printer en controleer voor eventuele fouten. 8. Als er geen fout verschijnt, plaatst u de andere cartridge. Sluit de printer te dekken. 9. Vervang de cartridge welke wordt veroorzaakt door de fout te verschijnen met een nieuwe cartridge.
Als het probleem aanhoudt, neem dan contact op met Lexmark Technical Support Center voor meer hulp.
Opmerking: Dit is omgerekend op basis van translate.google.com.
Aug 17, 2011 | Lexmark X3450 All-In-One InkJet Printer
How do I fix my printer, it is showing B200 error?
B200 error means "Print head Temperature exceeded". In your to solve your problem you need to perform a printer reset. Click Here to view the Canon reset guide or you can follow the steps below:
1) Hold the On/Off button for 1 sec. until the printer shuts off.
2) Unplug the USB cable and then the power cord.
3) Press the power button for 1 sec.
4) Wait 10 minutes, then plug the power cord back in and then the USB cable.
5) Press the power button to turn it on again.
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 22, 2011 | Canon PIXMA MP540 All-In-One InkJet...
De magenta cassette van mijn epson 7800 geeft steeds signaal "cassette is leeg -vervangen" de cass is niet leeg en als ik een nieuwe insteek blijf ik steeds hetzelfde signaal krijgen. ik heb al...
Ik neem voor het gemak aan dat het om de originele cartriges gaat.
Je zou eventueel de chips van twee inktpatronen onderling kunnen uitwisselen om te zien of de klacht met de chip mee verhuist of zich enkel bij Magenta voor doet.
Verhuist de klacht naar een andere kleur is de chip defect, blijft deze enkel bij magenta problemen geven dan kan het zijn dat de contacten in de inkthouder welke de tonerchip uitlezen niet in orde zijn.
Jan 06, 2011 | Epson Office Equipment & Supplies
Jan 03, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Problems with sgh-d900i
Hallo, als ik pc studio wil instaleren van sgh 900i geeft ie een foutcode -6001. Wat betekent dat, en wat kanik dr aan doen?
Sep 12, 2008 | Cell Phones
Zoek storings code f4 van gsfp3988
Jul 07, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
