Question about Norcent Technologies DP1800 System
Norcent DP1800G Does not play Region 1 DVDs
I cannot play Region 1 DVDs, it says wrong region when I insert my DVD, how do I change the region to my region???
  • Bradley Guindon Apr 28, 2013
    don't play purchased dvds they wont work, just burn them on dvd+r and dvd-rw disks lol
DVD says wrong region ?
hi Nigel.
Region codes prevent playback of DVDs in other geographical regions. If you receive a region error while playing a DVD with RealTimes, this means that the region code of the DVD does not match the region code of the DVD drive. ... You can play Region 2DVDs only on a DVD drive that is set for Region 2.
Region errors when playing DVDs with RealPlayer - SUPPORT
https://customer.real.com/.../204041263-Region-errors-when-playing-DVDs-with-RealPl...
How do you change the region on a DVD?Click Performance and Maintenance, and then click System. On the Hardware tab, click Device Manager. The DVD Region tab might not be available for all DVD drives. To configure your DVD drive to play discs from other regions, select a geographic area from the list of regions.
(you could try this link but what ever it tells you to do you do so at your own risk.)
Make Your DVD Player Region Free in Seconds
Nov 18, 2017 | Televison & Video
Changing dvd region codes
You can't change the DVD coding. That part is how the DVD is recorded. However, your Mac will play DVDs from another region. It just typically defaults to one region. I have deleted the DVD player software (and preferences files) before and reloaded it to play DVDs from another region. If you plan to regularly play DVDs from multiple regions, you might want to look for special DVD software that will read DVDs from multiple regions.
Jun 30, 2014 | Computers & Internet
My laptop only plays some dvds
You player is locked to a particular region and cannot play DVD from other regions unless the player is made Region Free or you install a Region Free program.
To changethe Region code on your DVD player, open Control Panel - System - Hardware -Device manager, and click on DVD/CD ROM drives, then right click on the DVDdrive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have beenmade.
NOTE you can make only 4 changes and the player will lock permanently on the4th change.
If you want to play DVDs from any region you maybe able to upgrade the firmwareto make it region free BUT if you make a mistake or installed the wrongfirmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From:-
www.dvdfab.com/products,free.htm
Jun 16, 2012 | Computers & Internet
Unlock the dvd code
DVD REGION FREE & BLUE-RAY REGION FREE
May 29, 2012 | Computers & Internet
My laptop is at region 1 and i want to change it to region 2 i have 1 attempt left
The best solution to make the player region free is to install a piece ofsoftware (Passkey for DVD) that allows you to play DVDs from any region andPasskey for Blu-ray that allows you to play Blu-rays from any region. There areseveral available on the Internet but my favourite is DVD-Region Free From: -
Apr 02, 2012 | E-Machines emachines (emachinees) CD-ROM...
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Nov 23, 2009 | HP Pavilion dv9000z Notebook
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Philips 7" DVD portable player
The PET702 will be a region 5 machine, whereas the UK DVDs are region 2.
DVD players from a particular region are designed to play only DVDs from the same region, due to copyright and distribution rights in each country or region.
However the PET702 can have the region protection removed by making it multi-region:
Switch on the PET702 and Open the tray.
Press SETUP button on the remote control, which will bring up the menu.
Highlight "PREFERENCES" and press OK.
Press [2], [5], [2], [3], [1], [5], [LEFT], [DOWN]
The screen will show: "Region Code: 2"
Press [1-6] to manually set the region OR [0] for multi-region.
You will now be able to play DVDs from anywhere in the world.
This is particularly useful, because region 1 DVDs from the US often come out when the movies are still in the cinemas over here. Region 1 DVDs can be bought perfectly legally by mail order or from the internet.
May 07, 2008 | Televison & Video
"wrong disc" display
I have the same problem with my DP313 Norcent. I found though that it will play recorded dvds. It also will play older Dvds and some Anime ones. It will play older recorded mp3s but NOT newer ones, I'm not sure if it's because they are burned at a faster rate or what. Also it will not play any of the new dvds except as stated before some of the Anime ones. It pays to try everything out to ensure it not a mechanical problem. I found it's not with mine, but still unsure why it won't play new dvds?
Oct 10, 2006 | Norcent Technologies DP313 DVD Player
Norcent Technologies DP1800 System Logo
Top Norcent Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Norcent Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
