Question about Custron T1062TYT For Toyota 4 Runner & Alpha & Alphard & Camry 2002 2003 2004 2005 2006 & Celica 2003 & Corolla 2003 2004 2005 2006 & FJ Cruiser & Previa & Vits & Vela & Hiace & Hilux & Land Cruiser & RAV4 & Sienna Sequoia & Tundra Solara & VIOS & Yaris Inda
Reset timing belt light - Custron T1062TYT For Toyota 4 Runner & Alpha & Alphard & Camry 2002 2003 2004 2005 2006 & Celica 2003 & Corolla 2003 2004 2005 2006 & FJ Cruiser & Previa & Vits & Vela & Hiace & Hilux & Land Cruiser & RAV4 & Sienna Sequoia & Tundra Solara & VIOS & Yaris Inda
How to reset timing belt light on 2015 toyota d4d
  • Cliford
  • Ignition(key) off press odo button.
  • Hold odo switch ignition on for 5 seconds.
  • Switch ignition off release odo.
  • Press odo, switch ignition on and continue holding until light goes off.
  • Switch key off and check by starting vehicle.
  • The light should now be off .
  • You can also veiw links below.
    • "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Toyota Dyna Landcrusier belt light reset
Toyota Hilux 6th generation BELT Light Reset on Denso Instrument Cluster
How to reset D4D belt light
Mar 03, 2016 | Toyota Cars & Trucks
When i press and hold the trip knob to fix the timing belt light nothing happens. What should i do?
If your timing belt symbol is on then its mileage controlled and trying to tell you something. Get the belt changed and the garage will reset the light. If the belt has just been changed then get the light reset.
Jun 02, 2015 | Cars & Trucks
Timing belt reset
Resetting by removing the positive battery terminal or press "clear code" on the diagnostic computer...
Hope this helps...
May 13, 2013 | Cars & Trucks
to reset the light you need to remove speedo dash assembly ,on the back of the printed curcuit there is a small screw and a hole next to it remove screw and fit to empty hole . refit assembly
Apr 29, 2009 | 1991 Toyota Pickup
Don't know how to reset timing belt warning light after belt repl
You must remove the dash panel and you'll find a screw just behind the warning light. You have to swap the screw place...it's written at the back "timing belt reset".
Feb 08, 2009 | 1996 Toyota 4Runner
Timing belt light of Toyota LandCruiser 2006
the reset procedure of the timing belt light is all done by pressing the trip meter button and holding it in whilst the ignition is turned to on then select from the trip button then continue pressing until you come to 15 on trip metre, turn off and then restart. The light should then go off.
Dec 27, 2008 | 2006 Toyota Land Cruiser
Time belt lamp 4 runner 1995
This light is to advise you that it is due for replacement. If its been done earlier the interval may not have been reset. Any dealer or someone with vehicle diagnostics gear should be able to reset it.
cheers John
Dec 19, 2008 | 1995 Toyota 4Runner
Land Cruiser mantenance
the site is legit, no one seems to exactly know what your talking about, is this a DVD RW DRIVE or a CAR??
what is it exactly.
Apr 07, 2008 | Alera Technologies Cruiser (270118)...
Custron T1062TYT For Toyota 4 Runner & Alpha & Alphard & Camry 2002 2003 2004 2005 2006 & Celica 2003 & Corolla 2003 2004 2005 2006 & FJ Cruiser & Previa & Vits & Vela & Hiace & Hilux & Land Cruiser & RAV4 & Sienna Sequoia & Tundra Solara & VIOS & Yaris Inda Logo
15 people viewed this question
Top Custron Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Custron Audio Player and Recorder Expert? Answer questions, earn points and help others
