The channels are 2 thru 13 or 14. We live in the Monterey Peninisula in CA
This could be a problem with weak signal strength of the channels in your area. You may need to get a amplified antenna to get better signal strength input into you television.You can buy these amplifiers already built into the antenna or use one as a add on to the input section of the antenna. Connecting the antenna to the television through it.They should be available in your local electronic stores like Fry's or the Micro Center. You can also buy them on line by using a search engine to find amplifiers for television antenna's. If you find that this is not your problem then you may want to contact the PROSCAN customer support at their website www.oncorpus.com and go to the customer support section.Give them the model number of your television and ask them for help with weak signal reception in the tuner section of your television. You can also call their customer support telephone number 1-888-977-6722. Give them the same information as above and they should be able to direct you to a service center, that can test and fix your problem. I hope this information helps you with your problem.
