Keep losing signal
Signal disappears every couple of minutes
  • 32,281 Answers
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply).
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Posted on Apr 28, 2013
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
2.8 hilux keeps losing power
check for fuel problems like air/fuel leaking at pump at the throttle shaft.
Mar 31, 2013 | Cars & Trucks
My lg shine keeps losing signal during a call. i have to remove battery and restart to get signal back and it only last for a couple of minutes before i have to repeat with restart of phone.
I know that this might sound crazy, but i had the same problem and found that if you hold your phone upside down it increases the signal. Also, take out your si and reset your phone if that doesnt work.
May 16, 2011 | LG Shine KE970 Cellular Phone
Toshiba 32AV500U HDTV keeps losing channel 2.1
check the location of their antenna and direction it is pointing . it possibly needs tweeked just a little toward the station transmitter
Mar 01, 2017 | Toshiba 32AV500U 32 in. LCD HDTV
Technics HD560 Losing Sound
Hello sir, there are several things you should check for, first the impedance of the amp and speakers, do they match 8ohms to 8ohms, two the amplifiers heat sink is it sufficient? or the amp. may need an extra cooling fan. third the main amplifier is the culprit. check each one and let me know if there is progress. thanks
Jul 18, 2009 | Audio Players & Recorders
Frequent sudden loss of radio signal
It looks like the problem is solved by adding an extra mass to the system.
Jun 20, 2009 | Blaupunkt Tokyo RDM169
My 2wire modem keeps diconnecting
hello,
this can be a couple of things one that you keep losing signal from your ISP keep an eye on your DSL nad ETHERNET light
if at any point they turn red call your ISP try not to set that modem to close to the monitor on the ground basicly any whenr where their could be static next to the refidurator or a TV
static make modem restart
another thing is that this might be early signs of your modem going to brake
, JULY
rate my service please
Apr 11, 2009 | 2wire (1000-000057-000) Modem
Signal on my tom tom
I have a raymarine C80 three in one GPS,Radar,depth sounder....no signal or scanner from radar on sreen it has power.
Mar 02, 2009 | Tomtom One XL GPS Receiver
Computers & Internet Logo
David Payne
David Payne
