Question about 94-1998 Chevy Silverado / Tahoe Grille Emblem Polished Smooth All Sale
Chevy pickup wont start
I had it running earlier in the day with everything running good. Next after driving 2 miles and shutting it off, it then wouldn't start. All the interior functions work, fan,door dinger,power window, etc. nut to turn the key you get absolutely nothing, no trying to turn over, nothing....what to do now
    Top Expert:
  • All Sales Master
  • 44,411 Answers
Have the battery load tested for cell failure. IT will have enough current for lights etc but not enough for the starter solenoid
Posted on Jul 29, 2013
2001 Tahoe will start but dies immediately
It is better to have a Higher Oil Pressure.. When shut off it reading 40 is just the gauge I would think. On my 78 Chevy the gauge will not zero out untill the next day when I go to start it and turn the key over. You might try running some Fuel stabilizer through it, Possibly a better Grade gas.. As the oil goes, If you are loosing oil I advise checking it Weekly, and add oil as needed.. to maintain the proper running level.. Change every 5000 miles or so as normal, Also Change filter each time you change the oil. I hope this helps a little. Good luck!
Mar 28, 2013 | 2001 Chevrolet Tahoe
1998 chevy s10 driving along and engine shut down.after sitting 10 min.it started but was rough.went 100.ft and it shut off again.sat for a while.it started and ran a couple miles like nothing was ever...
if it shuts off while driving and will not start back up for at least 10 minutes, then it may be the crank sensor doing this. is check engine light on! if so get it scanned to find problem code. if no scanner, auto-zone will scan for free. if light is on. CPS symtoms are: car dies and won't re-start till it cools down, or won't start at all. good-day ! crank sensor timing will be out of sync. it controls timing and sends info to pcm.
Jul 19, 2011 | 1998 Chevrolet S-10 Pickup
1993 6.5 desil turbo chevy 2500 5speed runs good when you drive it 40 miles and shut it off for 15or20 min it wont start backup unless you pull it or let it cool off overnight what could be wrong
FUEL DRIVER MODULE MOUNTED ON PUMP WILL CAUSE HARD TO NO START HOT
SMALL BLACK BOX MOUNTED ON DRIVER SIDE OF FUEL PUMP
TRY COOLING IT OFF WITH WATER NEXT TIME TO SEE IF TRUCK STARTS FASTER
May 08, 2011 | 1993 Chevrolet C/K 2500
Car wont even turn over batt is good 12.45v
The Water light? you may have over heated the car, also you may have caused a crack in the engine block by driving the car after the Temp light came on, Check the Thermostat, This may have caused the Light to come on and can cause some major problems if not replaced. Good luck!
Mar 19, 2010 | 1997 Volkswagen Jetta
Starts/stalls won't run until pedal tapped, 2 miles in town, 6 miles highway, then1000-1500 idle. shut down 9 hours, start/stall tap pedal runs return 6 mi. highway,2miles town same high idle. checked code...
Check your IAC motor (Idle Air Control) It could be sticking open.
Ps. Might be called Idle Speed Control motor it depends on the make and i forget what chevy calls theres.
Mar 11, 2010 | 2000 Chevrolet Malibu
I warmed it up and drove maybe one block and everything shut off, barley coasted off the road. next day it started right up so i let it warm up again, drove maybe 2 blocks and everything shut off again....
The fuel filter may have got to the end of it's life and will need to be replace. Start with the simple and replace the fuel filter. The filter should be replaced 15,000 mile or once a year to ensure that the fuel system is running 100%. Good luck and keep me posted.
Feb 17, 2010 | Buick Regal Cars & Trucks
1997 CHEVY BLAZER SHUTS OFF WHEN DRIVING
Sounds like water/debris in the gas tank. Try adding dry gas to the tank. Changing the fuel filter also a good idea.
Jun 19, 2009 | 1997 Chevrolet Blazer
95 Chevy S-10 starting issues
If the engine is turning over and it still wont start try shooting a little starting fluid in the air cleaner to see if it will run .. if so your fuel pump is either bad or the fuel filter is getting dirty.. thanks and holler if you need more Jerry
May 11, 2009 | 1998 Chevrolet S-10 Pickup
94-1998 Chevy Silverado / Tahoe Grille Emblem Polished Smooth All Sale Logo
98 people viewed this question
Top All Sales Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an All Sales Vehicle Part and Accessory Expert? Answer questions, earn points and help others
