Error code f8 westinghouse mini split - Heating & Cooling
3 Suggested Answers
  • 234 Answers
SOURCE: My mini split shows f8 and turns on/off alone
The unit is going off on a hi temp .Can you leave it off for a while and then it will start up if you turn it on?I would be checking the fan motor to see it will run alone when the unit stops.Also check and see how hot it is at that time.
Posted on Apr 07, 2009
  • 51 Answers
SOURCE: yonan ac split mini 1.5 ton error codes E1
CHECK ROLLOUT SWITCH AND CHECK FOR A POSSIBLE
GROUND FAULT..OR FUSE..
Posted on Apr 13, 2010
LENOX MINI SPLIT HAS A F8 CODE ON THE SCREEN
Cycle the power to the outdoor unit. F8 is a low or high line voltage fault. Not likely a real error if the unit has worked in the past. Possible power surge or something.
Jun 01, 2017 | Heating & Cooling
What is F8 error in a westinhouse mini split?
Feature : F8 Error code on indoor unit display panel
  • Answer :Reason:
    Outdoor moter abnormal.
    Solution:
    This is usually be caused by the outdoor motor fault or outdoor PCB fault, and it couldn't be fixed by customer. Please call for service for help
May 03, 2017 | Heating & Cooling
F8 error split air conditioner
F8 error isn't registered with my Daikin Airconditioner, though E7 showed up as a 'motor over-current' warning.
It might help if you find out the NAME and the MODEL NUMBER for your air conditioner.
Once you know this, then you can search for it like this...
Name - Model - error codes
E.g. 'Daikin Ft18k error codes'
Oct 06, 2014 | Computers & Internet
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
What is a code c1 on a samsung mini split?
Error code = C1 or CH1
Fault = Indoor temperature sensor open or closed circuit.
Jul 26, 2014 | Samsung AQV12VBCN Vivace Mirror Finish...
Soleus dual mini split KFMHP18 fault error F1
F1 error code is a communication failure between the outdoor and indoor units. Check all inter-connecting wires. They should be minimum 14g stranded wire. Make sure all electrical connections are tight. These units are manufactured by CHIGO, you may try to contact them.
Aug 10, 2013 | Soleus Ductless Mini Split 18000 Air...
Westinghouse error code FF airaconditioner split
model:WlFXL-36SVW2
error FF what does could be the problem
Sep 14, 2011 | Heating & Cooling
Displayed F8 error
The F8 Fault means that the Temp sensor in the indoor unit that goes into the cooling coil is faulty.
Jun 15, 2011 | LG LS-L1210CL Mini Split Air Conditioner
F8 error
F8 on tamashi ac
Jul 03, 2010 | LG Heating & Cooling
Heating & Cooling Logo
675 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
