Question about Watches
Guess watch I can't find this exact watch anywhere on any guess.com sites or any sites that sell guess watches. How do I find the value of this watch?
    New Friend:
First you must take a good fotog.of that watch.Because is very hard to detrm.what kinde of Gues watch is it!!!
Posted on May 02, 2013
SOURCE: how do i find out how much my citizen watch is worth?
I don't know about a web site, but if you go to the library they should have a book that gives you all the answers you are looking for. If you can't find it , please let me know .I will be glad to find the book for you. Good Luck!!
Posted on Aug 11, 2008
escapement
  • 2334 Answers
SOURCE: how do I adjust band on a guess g95290g guess steel mens watch ?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Feb 16, 2009
  • 4 Answers
SOURCE: Where can I find Casio Watch spare parts? My watch
replica Watches
Posted on Sep 09, 2009
SOURCE: replace a battery cover in a guess watch
Your watch case back (battery cover) actually lost it shape some how that's why it's not closing, it's need alignment,
which take lots of time try expert watchmaker hope you get it fix.
even thought it fix some time it's lost capability to keep your watch save from water.
hope this info help
From
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Oct 01, 2009
SOURCE: Guess Watch's stop watch is broken?
it's not broken.
let's call the top stopwatch button "a" and the bottom stopwatch button "b." eg, for normal stop watch function press "a" to start timing, press "a" to stop timing, and press "b" to reset.
to reset: press button "a" and "b" simultaneously and release (an easy way to do this is press and hold down "b" then press "a" and release both). this will send both hands spinning. next press "a" intermittently until the second-hand is back to it's desired reset location. then, likewise, press "b" intermittently until the minute hand is zeroed. now with both hands at the correct reset location, again press and release "a" and "b" simultaneously to save these resets and return the watch to normal function mode.
Posted on Oct 07, 2009
I need a watch link for the guess U0379G4
Contact & Help ' GUESS Watches
guesswatches.com/customer-help
Get in touch, find your local representative and check for FAQs and watch care tips.
Guess Watch Links ' eBay
www.ebay.com/bhp/guess-watch-links Find great deals on eBay for Guess Watch Links in Wristwatches. ... Authentic Navy Blue GUESS Watch Extra Links and Bag Included (See Picture) Battery NOT ...
GUESS Watches, Parts & Accessories ' eBay
https://www.ebay.com > ... > GUESS Watches, Parts & Accessories Shop from the world's largest selection and best deals for GUESS Watches, Parts & Accessories. Shop with confidence on eBay!
guess watch extra links Google Search
Aug 07, 2017 | Guess Watches
Cannot change the time
Gc Watches ' World Time - YouTube
? 2:53
https://www.youtube.com/watch?v=wxXNcb3VjYM
Sep 6, 2013 - Uploaded by Ceasmania Shop
Ceasmania este cel mai important site romanesc privind vanzarea ceasurilor si bijuteriilor marca Guess ...
Guess Gc Watches Sport Class XXL Review - YouTube
? 4:04
https://www.youtube.com/watch?v=hZxtnZFdjnA
May 8, 2013 - Uploaded by aBlogtoWatch.com
aBlogtoWatch watch review of the men's Gc (Guess Collection) Sport ... Show more ... Not like a cheap watch that gets scratches over time..
Guess Watch Guide on How To Adjust Time & Use ...
? 1:37
https://www.youtube.com/watch?v=V2FPk-6mD7g
Nov 29, 2011 - Uploaded by Jade Bryan Jardinico
Download Manual for all Guess Watches: ... Guess Watch Guide on How To Adjust Time & Use Stopwatch (W17540G2 50m ...Show more
[PDF]GUESS Watches
Jan 10, 2016 | Watches
How do you set the time on a Gc mens xl series watch
? 2:53
... privind vanzarea ceasurilor si bijuteriilor marca Guess, GC si Escape. ... Gc Men's Classic watch ...
? 4:04
aBlogtoWatch watch review of the men's Gc (Guess Collection) Sport Class XXL ref. ... Show more ...
[PDF]GUESS Watches - Rackcdn.com
Dec 28, 2015 | Watches
Guess watches
Determine the exact numbers on the back of the watch and list any and all writing on the front as well. With out that, it's shiny piece of metal to most of us. Usually, however, that brand is a department store type product. It'll run anywhere from 100-200 bucks. Sometimes more, sometimes less. More info means more accuracy. A pic or vid won't help unless someone had that exact piece and remembers what it cost them, way back when.
Apr 28, 2013 | Watches
I want to ask whether it is possible for this model GUESS WOMEN'S WATCH W14033L3 PYTHON GREEN LEATHER MUSE to order through which site this same leather bracelet, because I already have this model of a...
Beautiful watch. Very classy. Easy to adjust band with two links that can be removed from the bracket. Large round face with easy to read dial. The bracket construction is especially unique with the two different types of finish. GUESS Women Stainless Steel Leather Casual Watch Color Red Model U0627L5
Feb 12, 2018 | Watches
I have a GC G36001L1 and the pin that connects the band to the bezel ust broke. Is there a replacement for this?
Solange - have you contacted Guess customer service? They may repair/replace the watch or watch part for a minimal (or no) charge.
Toll Free: 1-877-44-GUESS (48377).
Monday through Friday 6:00 a.m. - 5:00 p.m., Saturday 7 a.m. - 4 p.m. (PT)
Regards,
DIYpro
Jun 10, 2011 | Guess Gc Collection Diver Chic G36001L1...
Watch glass broken Paul Cotello ladies watch., cant find anything anywhere online for that make.
<P>Thank you for contacting FIXYA.</P><P>Most watches you can take to a local watchmaker and they can actually cut MOST crystals. It really depends on the style of the watch. You may want to contact a local watchmaker first, but here is a site you can try also:</P><P><A href="http://www.crystalfit.com/">http://www.crystalfit.com/</A></P><P>You are right, Couldnt find anything about that brand on line. </P><P>Best regards.</P>
Aug 24, 2010 | Guess G85675G WristwWatch
Ihave a guess waterpro titanium watch but
I guess you go to Guess site, fill the details and then find out if you can get the watch manual/instructions. Here is the link: http://www.guess.eu/CustomerCare/ContactUs.aspx If you can't find what you want, it does not mean I gave you the wrong direction, as this is original site.
Jan 24, 2010 | Bulova Watch
Watches Logo
44 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
