Question about D-Link D Link Dir 601 Wireless N Home Router Transmission Speed 1875 Mbps Maximum Frequency 240 Ghz
91 dodge stealth
Transmission sensor
  • 7,627 Answers
Post to Cars & Trucks category for a Car expert.
Posted on Apr 30, 2013
91 dodge stealth
U definitely do have a thermal issue with the traits you have described. The diagnosis you got is spot on. But shop around for the part since most places will not allow the return of electronic parts.
Sep 06, 2017 | 1991 Dodge Stealth
91 dodge stealth
try clean the butterfly in your throttle body .with throttle body cleaner. but i have to say it may be your throttle position sensor has failed
Dec 13, 2013 | Cars & Trucks
Where is a fuel pump relay located on a 1993 dodge stealth non turbo
the fuel pump relay on a 91 to 93 dodge stealth base and es models is in the passenger area on the passanger side of the car there a lil kick panel held by one screw behind a black cap pull the panel of and its right behind it.. its a gold box with wire harness connected at bottom. its a 2 part relay that controls ur fuel pump and engine managment system. email me at joshuaelliott2009@yahoo.com if u would like a pic of were it is at
Oct 23, 2010 | 1993 Dodge Stealth
I have a 1991 dodge stealth dohc and removed th cas sensor with out marking the old one what is the proper way to install the new one.
Marking does not matter that much because you always need to reset the timing anyway.
Here is a link for crank and cam position sensor replacement:
http://www.stealth316.com/2-cas-91-92.htm
And here is one for timing:
http://www.stealth316.com/2-ignition-timing.htm
It is just like any distributor timing except that you have to ground the right test connector, otherwise the ECU will vary the timing based on things like temperature, knock, fuel, etc.
Aug 08, 2010 | 1991 Dodge Stealth
Witch timing marks do I use for my dohc 91 dodge stealth?
I don't know what you got there, but, the marks are just dots, or little arrows, they have to line up or else. I don't think the cam can go in but one way, all 4 valves opening at once doesn't make sense to me but I'll check it out.
Mar 06, 2010 | 1991 Dodge Stealth
91 dodge stealth will start and stop. Changed the fuel pump and computer chip. Now what?
Have you checked or replaced the fuel filter? Sometimes that can be the problem as well because your fuel filter could be clogged.
Jan 28, 2010 | 1991 Dodge Stealth
My 91 dodge stealth is in limp mode how do i fix this transmission problem
Your car is in "limp"mode because the computer doesn't know what speed your doing,So it doesn't shift,
There are three possible reasons for this,
#1= input sensor faulty on transmission,
#2=output sensor faulty on transmission,
#3=speed sensor faulty on transmission,
you need to have the transmission codes read to know which one,Autozone checks codes for free.
Jan 13, 2010 | 1991 Dodge Stealth
D-Link D Link Dir 601 Wireless N Home Router Transmission Speed 1875 Mbps Maximum Frequency 240 Ghz Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
