Question about Dryers
Electricity i have 120 volts going to outlest and when I plug something in, the light over bench gets brighter, and whatever I plug into them does not run at speed.
    President:
  • 1,082 Answers
You should have a qulifed electrician check it out. Sounds like you may have a ground fault. An electronics store may have a simple plug in diagnostic device, which may give you a clear answer, or just a clue as to th real issue..
Posted on Apr 28, 2013
4 Suggested Answers
  • 120 Answers
SOURCE: It does not turn on, no electricity gets to the control panel
check the door switch. it should click when you operate it with your finger. that is a common and easy fix. good luck
Posted on Nov 13, 2009
  • 1891 Answers
SOURCE: 3 wire plug Maytag dryer, but a 2 wire prung outlet@120 volts.
your dryer can be wired to run on 120 / i would not do / very costley to run . . this is some times done for display on the sales floor . best is to get gas dryer or have 220 wired to dryer .. if in home . **** ..
Posted on Dec 08, 2009
  • 17 Answers
SOURCE: Whirlpool gas dryer: 120 volt plugged
it is possible. But first check the pcb fuse or board and even the transformer for the pcb board if theres a burn out replaced it. 2nd you check the motor if theres a resistance or no continuity or grounded. then replace it .
Posted on Feb 07, 2011
2003 gulf stream prairie schooner 5th wheel computer box/electrical problem
ac runs off 120 volts refrigerator 120 volts heater element 12 volt heater element and control board outside lights 12 volt ceiling fan 12 volts wires that go to box 2 blue furnace 12 volt wires from thermostat 12 volt
May 10, 2017 | RVs
Can You Set Up Dryer To Use 110 Plug ( Standard Plug)?
buy a gas dryer,that uses 120 volts.but electric that uses 240 volts can't be set up to 120 volt.,i've seen electric dryers that are set up for 120 volts but they take a very long time to dry the clothes.http://www.ajmadison.com/cgi-bin/ajmadison/LDR3822PQ.html you can look at some of them.
Dec 09, 2011 | Roper REX3614KW Electric Dryer
I AM GETTING ELECTRICITY TO THE 220 PLUG AND THROUGH THE 220 PLUG WIRE TO THE STOVE JUNCTION BOX. THE STOVE TOP AND OVEN HEATING ELEMENTS ARE NOT HEATING UP BUT THE INDICATOR LIGHTS FOR BOTH ELEMENTS SHOW...
The indicator lights operate on 120 volts whereas the elements operate on 220 volts.
Using an electrical test meter go between the two hot legs and see if you are getting 220 volts. If not you have an open or non completed circuit.
Do not test from one leg to ground as you will probably read 120 volts for each leg. By reading across both legs you should get 220 volts.
May 03, 2011 | Microwave Ovens
I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
Joe
Feb 28, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
We have a Fisher and Paykel Model #DEC27CW1 All of a sudden it stopped heating. Is there something we can check other than the vent, which is clear?
Dryers work on two 120 volt circuits which is why the breaker in your electrical panel is twice as wide as a normal breaker. If you can get an electrical tester you can check the wall plug to ensure you are getting at least 220 volts from the two straight plug holes. Put the tester on AC Volts, place one lead to one side and the other to the other slot. If you have a problem getting this to work you can also go from the slot to the round plug hole. Then again from the other side to the round plug hole, doing it this way you should get 120 volts.
Sep 14, 2010 | Fisher and Paykel DEGX1 Electric Dryer
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Going from 3 prong wall plug to 4 prong?
remove cover take a volt meter with one lead on center lug and one on the right lug should read 120 volts , then with one on center lug and one on left should read 120 volt , then with one on the left and one on the right should read 240 volts careful always when checking live voltage void electrical shock
Dec 30, 2008 | Kenmore 659 Electric Dryer
Kenmore electric range 7909083461 not reaching temp
The technician is right.  The electrician should know that amperage X voltage = wattage.  So if you lower the voltage then you lower the wattage.  The element is like a light bulb, the higher the wattage the brighter or hotter it will be.  208 volts is at the minimum so the element won't be as hot as it should be.  208 volts is just enough to make it work.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Kitchen Ranges
120 volts 50 hz
hi the Electrical Requirements of this device: 15 OR 20 Ampere, 120 Volts, 60 Hertz (1/second). go to elctronics shop with these details and buy a transformer wich will translate your current Volt\ampere\frequency to what the device needs wich from what i understand needs higher frequency http://www.whirlpool.com/catalog/product.jsp?parentCategoryId=113&categoryId=115&subCategoryId=116&productId=218&view=2#tabs good luck
Mar 24, 2006 | Whirlpool GHW9400 Front Load Washer
Dryers Logo
29 people viewed this question
Top Dryers Experts
