Dremel 200-1/15 - 200 Series 2 Speed Rotary W/Atch & 15 Asst Accs Logo
Anonymous Posted on Apr 28, 2013
How to fix Dremel, it stopped working - Dremel 200-1/15 - 200 Series 2 Speed Rotary W/Atch & 15 Asst Accs
2answers
My 4200 Dremel over heated and stopped working. The book said to replace both the Brush and the springs. I did that and it still does not work. Plugged in to other outlets and it still did not work?
It's possible that the enameled copper coiling on the stator was compromised when it overheated creating a short. Sadly, unless you have a replacement stator is cannot be fixed. Sorry.
Why has my dremel 6000 just stopped working could it be the brushes
Although Supergrit Abrasives in Gettysburg, PA sells the sleeves and the Hook & Loop diamonds for use with the Dremel 6000, we do not repair tools. The 6000 is discontinued, but you can probably buy a used one that works on Ebay.
Dremel 3000 stopped
My Dremel 3000 suddenly stopped working also. No idea where the receipt was so i decided to investigate. I found one of the two stator windings had blown. I'd Barely used the thing, so that's the last dremel I'll be wasting my money on.
36helpful
5answers
Dremel MultiMax 6300 has stoped working Will not turn on.
Mine died also. It's the on off switch. Where can I get parts?
I have a dremel multi master that suddenly quit. my first one did the same thing I did kick the **** out of the first one and got my moneys worth. the next one died suddenly , wasnt overheated and used...
they do that a lot dont they? sorry all you can do is strip it down and see if there is a fault in it that an easy fix but normaly they just go in the bin when they stop working
1helpful
2answers
I own a Dremel model 395 type 5 variable speed and it suddenly stopped working. I was wondering if it was common for the switches to go bad or if it's known for other parts to cause it not to turn on.
I would recommend going to Dremel.com and asking their tech section about this. I have one also and mine works fine other than a small amount of heat at the spindle area.
2answers
New Dremel 300 stopped working. What's wrong?
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
1helpful
Dremel 398 is dead as a Dodo.
I would contact Dremel direct at 1-800-437-3635 or Dremel.com and talk with one of their techs about this tool. Let me know if this doesn't work
5helpful
I have a Dremel Single Speed Model 275 that belonged to my Dad. It suddenly won't turn on the end even though the motor is running at full speed. When I take my fingers and twist the end, it starts to turn...
The Dremel 275 (and other series) have a plastic coupler and spline that connect the motor shaft to the collet shaft (where the tools attach). The plastic fatigues and disintegrates, causing the collet shaft to stop, even if the motor is still running. The fix is about $5.00 --- two parts from Dremel. The 275 case is a **** shell that opens with the removal of six T-10 Torx screws.
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
