Question about Sony Bravia Kdl-55ex500 Series 55-inch Lcd Tv, Black
Auto tune sony bravia
Auto tuning does not detect Seven Networks (177.5 MHz) and SBS (184.5 Mhz) in one antenna output point, but able to do so in another antenna output point in another TV
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
  • 56 Answers
SOURCE: convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Posted on Jun 12, 2009
  • 909 Answers
SOURCE: I have a Sony KD-28DL10U tv with integrated
I have the 32" version. I found out, accidently that to reset the TV, with the TV on, pull the mains plug slowly, you should hear a pop, leave for 5 mins and plug back in, I won't take any responsability for damage so you will have to do only as last resort. I also found it is a problem with 1st and 2nd generation digital sony's. Mine was "upgraded by sony but to no avail hence the need for a HARD reset. It doesn't actually reset anything, just clears a frozen tuner.
Posted on Jun 23, 2009
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
SOURCE: My Sony KD28DL10U digital TV will not tune into freeview
I think this is one of the TV's that wont work as part of the Digital Switchover as it's too old. My Brother has the same TV and has had to buy a new Set top box to get Freeview.
Posted on Oct 21, 2009
Why my connection speed to WRT-688 only shows 72Mbps not 150Mbps?
Ok, connection speed depends on few things:
1) Spatial streams (or pipes and antennae) you have on each side of the link (e.g. in your device's wireless card and your router)
2) Selected Channel Width ( auto, 20 or 40 Mhz).
3) Channel your router is broadcasting on and the noise and interference of neighbouring networks in the selected channel.
In order to achieve the highest wireless speed possible :
1) It is better to at least match the number of spatial streams ( or simultaneous connections in your wireless adapter,
2) Activate a channel width of auto, (which will check and switch channel width according to the good neighbour policy) or manually force it to use 40 Mhz mode (often called afterburner) both in your router and your device wifi driver. Auto mode will check if 40 Mhz mode is supported, and, if does not interfere with neighbouring networks it will switch to it automatically. 40 Mhz mode uses two channels separated by a gap of 5 channels to pass data instead of only one, so there can be signal overlapping and interference.
3) And finally, if there is congestion on any given channel you use try to set up your router so it uses a less congested one. (recommended channels are 1, 6 and 11 because with these you can have the chance to use dual channel with the least overlapping and noise).
I'm attaching the next chart because it may be useful to you when trying to understand more about wireless channels and their implications as this clearly depicts them.
Hope this helps you.
Jan 07, 2014 | Computers & Internet
Sony Bravia has lost all channels besides ABC and 7 Network, this happened while the TV was on, what is wrong?
unless you are on a antenna look in the menu to make sure set is on catv and not air or antenna.
Sep 03, 2012 | Sony Bravia KDL-32XBR9 32 in. LCD HDTV
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
My Grundig Satellit 700 Radio is not working on FM Band but is working well on AM and Shortwave Band. After pressing ON/OFF button and FM/RDS-AF button when we try to operate the FM Band of this radio...
As a side note, most AM/FM radios use a separate antenna for each band, thus why you can pick up AM but not FM. Check your mast antenna connections to make sure they are solid and not missing or loose.
Dec 10, 2010 | Grundig Audio Players & Recorders
Ram
Your motherboard can take DDR or DDR2 RAM modules.
Crucial says: "Each memory slot can hold DDR PC2700,DDR PC3200,DDR2 PC2-5300 with a maximum of 1GB per slot." No sense getting 4GB since the max is 2GB.
You can get higher speed RAM (PC2-6400) because it is backward compatible.
I would go with the 2 X 1GB Corsair from the ones listed.
Or consider the options on Crucial's site. See this page:
http://www.crucial.com/store/listparts.aspx?model=P5VDC-MX
Two 1GB modules of DDR2 PC2-5300 run about $34 US.
(PS. Your 450W power supply will handle about anything.)
Jun 03, 2009 | ASUS P5VDC-MX Motherboard
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
Sony Bravia Kdl-55ex500 Series 55-inch Lcd Tv, Black Logo
24 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
