Question about Canon GL1 Mini DV Digital Camcorder
Canon GL1 Remove cassette error
This has happened to the last 3 tapes i've put into my GL1. I film fine with them and then i start to rewind and it rewinds for about 15 seconds and then says "REMOVE CASSETTE". I try putting it back in and the second it closes it starts beeping and telling me to remove it again. But then when i put a brand new tape in it is fine, until i rewind it and then it won't let me use it. I don't think it has anything to do with condensation because it only happens on rewind and new tapes work fine
  • 1 more comment
  • areyouthere Jun 03, 2008
    i have the same problem , i even tried a head cleaner...as soon as the door closes it ask you to remove the tape.
    the problem started when i switched from JVC tapes to FUJIFILM....i taped about 10 minutes on the FUJI tape and rewound it then the tape needed to be removed.
  • Anonymous Jun 21, 2008
    I have the same problem.. it only happened once I started using Fuji and sony tapes
  • Anonymous Mar 19, 2014
    REMOVe cassette
I certainly don't intend to be rude or obnotious but your comments on this known prpblem are contraditory to say the least! :
"The problem that you are experiencing with your Canon GL1 camcorder is a common complaint on this model camcorder. The “eject the tape error” is the camcorders way of saying something is wrong and it needs to be sent in for repair. It is not a defect with the camcorder, it is simply the most common complaint when the mechanical assembly is not running smoothly and perfectly." If something is wrong and it's a common problem then it must be defect?!?! Also your pricing for this "repair" is pretty close half of what a used GL goes for over here in Europe. I would definatly be looking for another quote and repair service other than yours!
Posted on Aug 20, 2008
    New Friend:
Dry head cleaner.
Solved problem for me.
Posted on Jun 14, 2010
SOURCE:
My Sony DCR-TRV740 camera I just purchased (used), has a playback problem with my 8mm's. When I got the unit I cleaned it well with chamois swaps and MG video cleaner(Recommended by all experts it see
You have a clogged video head. It happens. Do not use the chamois again. Instead, purchase an 8mm head cleaner and give that a try. Only use a brand name cleaner - no generics, and make sure it doesn't come from China!
Nov 07, 2014 | Sony Handycam DCR-TRV740 Digital Camcorder
Camcorder VHS tape is tangled
Sometimes you can salvage a VHS tape by opening the cassette and manually winding or rewinding the tape to put the damaged section to one side and under tension to "iron out" the wrinkles. Your Fuji Hi8 tape may be quite thin so this repair may not work.
Dec 18, 2013 | Canon ES300V ES4000 ES410V and ES420V ES50...
Panasonic PV-7400 VHS VCR seems to be stuck in Memory Rewind Off mode. I power on, it attempts to rewind (though there is no tape in there now) for about 20 seconds, then powers off. I've pulled
Most of these problems are caused by a faulty mode switch. If the mode switch has gone off of it's true position, then the electronics might well think it's in rewind mode even in the off position. Sometimes it's just the switch that is faulty, but sometimes damage to the mechanism has thrown off the switch.
Apr 14, 2013 | Televison & Video
Blue screen no playback with tape glitching canon gl1
Have the previous owner demonstrate that it is fully functional.
Jan 08, 2018 | Canon GL1 Mini DV Digital Camcorder
My canon eos 1000 keeps on rewinding the film into the cannister when i put a new film in
The XS normally winds the film completely out of the cassette and then rewinds it back into the cassette as you take pictures
Feb 08, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Why did people need rewinders? didnt the VCR have a rewind button?
they need them as kids watch the films and not rewind them when they finished as they wanted to watch another film....
Jan 29, 2013 | GE lectric Slimline 1Way VHS Rewinder...
Nikon f601 won't rewind
needs repairing at a qualified shop
Sep 06, 2012 | Nikon F601 35mm SLR Camera
Canon GL1 message to eject tape... I want to transfer it to puter. any suggestions?
Canon GL1 was working fine last night,now it want do ANYTHING today,want power up or anything,want even eject tape when I push eject button. Any suggestions?
Jun 25, 2010 | Canon GL1 Mini DV Digital Camcorder
My canon vixia hv30 camcorder is not reading tapes anymore. It rewinds and forwards and reports the tape position but the tape counter does not roll showing only dashes as if the tape is empty. All this...
It sounds like the tape itself is damaged. Get an head cleaner cassett and clean the mechanism. This will clean the wheels and heads that tape runs over. Also try a new tape cassett to see what happens and listen to the camcorder for any crunching sounds as this would suggest that something has broken inside the camcorder.
Good luck.
Jun 29, 2010 | Cameras
Canon GL1 Mini DV Digital Camcorder Logo
1,645 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
