Question about Dell Computers & Internet
Missing driver headphone jack - Dell Computers & Internet
    Brigadier General:
  • Dell Master
  • 3,400 Answers
Bob it's six contacts on the I/O SHIELD COLOUR-CODED.lightgreen audio out,purple mic etc, etc i think pink is for hedphones you find out.
Posted on Apr 28, 2013
Headphone jack driver
There is no driver for the analog output. Make sure you have selected the computer internal speakers and the headphone jack will take that output. A more likely cause for your issue is the contacts inside the jack are sprung and are not making contact. If that is the case then the jack needs to be replaced.
Mar 10, 2014 | Acer Computers & Internet
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Feb 16, 2014 | Audio Players & Recorders
Headphone port does not work on acer aspire 5250
Click Start, Go to control panel, then Hardware and Sound, then Sound. Click "manage audio devices". Plug in your headphones and see if they show up.
If they don't, your divers are missing or the the headphone jack is broken or clogged. The most common reason they don't show up is actually gunk in the jack, so make sure it's clean with a bright flashlight and use a toothpick or something similar to clean it out.
If they don't show up and your jack is clean, use windows update (it will detect many of your missing drivers) or go to acer.com, click on support, drivers, and enter your model number and download the audio driver and install it.
If you DO see the headphones show up as an audio device. Then just set them as default (by clicking "set as default") and it will work.
Hope this helps!
Sep 21, 2013 | Computers & Internet
My headset is not working
Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Jan 16, 2013 | Computers & Internet
Dell laptop headphone sound on out headphone no sound
Sound Loss in Dell Computer Headphones b> Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
b>
Dec 29, 2012 | Hitachi VisionDesk 1330 (1330-001) PC...
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
Headphone is not detected in lenovo g 460
Go to the control panel, then to hardware and sound, then sound. You should see something called manage audio devices. Plug in your headphones and see if they show up.
If they don't, then either your divers(these things will tell your computer what kind of hardware it has and how to use it) are missing or the the headphone jack itself has failed. Lets say it is in fact your drivers that are missing, then all you need to do is either use windows update(it will detect many of your missing drivers) or go to the manufacturers website and look for them there(usually they will have a tab somewhere on the home page that will say something about support or downloads). And also try different headphones, those could have messed up as well.
Now lets say that you do see the headphones show up as an audio device. Then all you need to do is set them as the default and that should fix your problem. Though I will say that I currently have a problem with switching between the two. Once I start a program such as media player, it will stick with the current default audio device.
Mar 05, 2011 | Lenovo G460 Notebook
I am having the same problem with a twist, sound works from the fm and headphone but only from the right side no left audio. I have the 760 and it only has one speaker and my guess it that it gets its feed...
If you use the headphone jack a lot and your missing the audio from the speaker and one channel from the headphone jack, then it's possible that some of the headphone jack connections have broken off of the PC board. The audio goes to the speaker through the headphone jack.
Please see this link for more info and read the section about the headphone jack.
http://www.sharc.net/gps_audio_repair.htm
- Jim
Dec 19, 2009 | Garmin Nuvi 760 Car GPS Receiver
No sound from my notebook laptop
1.check the master volume ( will be a function key and / or dial)
2.make sure volume is not muted on computer (setting found when you double click on the little speaker icon by your clock on the lower right corner of your desktop)
3. plug some headphones into the headphone jack and check for sound there
4. click START-SETTINGS - CONTROL PANEL - STSTEM -select the HARDWARE tab at the top -
device manager- when it opens , scroll down to where it says "sound video and game controllers, if it has a yellow ! next to your device, the drivers are missing or corupt and need to be installed or updated and can be done so at your computer manufacturers' website.
NOTE- if you have headphones plugged into the headphone jack it WILL mute the system except in the headphones.
please post your findings here and we'll move to another step if needed .
Regards!
Oct 29, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Alun Cox
