The instructions for IBM Infoprint 1412/1512 printer's photoconductor is the same as the Lexmark E342.
The instructions are located here:
http://support.lexmark.com/index?page=content&id=HO2564&locale=en&userlocale=EN_US Recap of Instructions:
To Reset Photoconductor page count:
1. Turn off printer
2. Press and hold the Select and Return buttons at the same time on the panel and turn the printer on (continue holding down buttons until printer screen displays "Performing Self Test" or "CONFIG MENU").
3. If "Reset PC Cnt" does not appear on screen, press the left or right menu button until it appears.
4. Press "Select" and the message "Resettting PC Cnt Value" should briefly appear indicating the page count is reset.
5. Turn off printer when "CONFIG MENU" appears again.
6. Wait 5 or more seconds and turn back on. Done.
7. It is suggested to check and verify that the PC Count is reset by printing a menu setting page:
a. Press left or right menu buttons until you see "Utilities Menu" and press "Select".
b. Press left or right menu button until you see "Print Menus" and press "Select".
c. This should print out the information. Look for "Cartridge Info" and the word "Photoconductor". It should indicate "OK" or close to 100%.
d. If not showing "OK", print 10-20 pages and Print Menu again to check. If still not, reset PC again and check again.
