Question about Mitsubishi WS-55613 55" Rear Projection HDTV
How to turn on internal speakers
I have a mitsubishi wd-65767, I try to adjust the volume and it says internal speakers are turned off. I do not have the original remote, only a universal remote. How can I turn the speakers back on?
techman
  • 3130 Answers
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
Posted on Jun 16, 2006
hardrocko
  • 1476 Answers
SOURCE: No volume
You need to get into the audio menu and turn the speaker on. Usually even without the remote the control the buttons on the set will allow this. Sometimes they are not marked but usually pushing two buttons at once, or holding one while pushing another will work. Experimentation should yield which ones work. Once you are in the menu it should be easy to get to the audio controls using the buttons on the front. Again experimentation and retrys may be required. When you find the correct menu toggle the speaker back on and you should be good. If you don't mind spending the money, and it may make your life easier down the road, this website http://www.remotes.com/ has your factory remote for $67.20 plus shipping. A cheaper alternative may be to buy a universal remote for 5 to 10 dollars but there is no garantee that it will allow you to access the menus. Good luck.
Posted on Jul 12, 2006
SOURCE: mitsubishi HD 1080 series model ws-65807 no volume.
You need a remote. There are places that sell them, but you can usually get by with your cable box remote or some other modestly programmable remote. It would help if you had an owner's manual. You can probably find one on line. It is a bit of a dance to make the menus work correctly.
My set is gone, but you have fairly ordinary on-screen menus. One of them is for sound on or sound off to the internals. That so that there isn't the conflict between speakers from a receiver based audio setup. You should have external speaker outlets on the set itself. If you do, plut in a speaker you're not worried about. you should get sound out from there.or use an audio out connection to a receiver, etc.
Posted on Jan 22, 2009
rulds2008
  • 3866 Answers
SOURCE: cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Posted on Jul 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: Replacement Remote
Hi
Thanks for using FixYa. Yes Universal remote control can be used on Mitsubishi TV CS32307 for which you can place order on the following link---
Replacement Remote Control for Mitsubishi TV CS32307
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 31, 2009
How do I turn on internal speakers?
Hi Robert,
Please go to sound menu, you will find option for internal and external speakers there.
Jun 28, 2015 | Mitsubishi WD-73742 3D DLP Home Cinema TV
Wd 65738 sound card
what sources do you have connected to the tv?
If you have more than one source, have you tried another source to see if it also has no sound. The TV also has a setting in the audio menu to turn off the internal speakers.
Nov 14, 2013 | Mitsubishi WD-62725 62" Rear Projection...
Model wd-60737 no volume
Look first to see if sound gone on all inputs---use a DVD etc connected to a input
Make sure in the menu speakers are not turned to OFF
last resort try the soft restore this model should have--menu, 1,2,3 enter
Set also has a hard reset but uses a different code I do not have.
Dec 05, 2012 | Mitsubishi WD-60737 TV
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
I have a Mitsubishi cs-35505 tv. This model is an oldie, from '96, but still works... kind of. The remote is not really functional, even with new batteries and the internal speakers got turned off. I...
If you feel the remote is bad, you will need to find a new remote. The best option here is to find the MCM Electronics website. They will have a brand replacement. Thanks for asking and show a few hands of support!
Mar 21, 2011 | Mitsubishi CS-35405 TV
How do I turn up volumn on the wd-65735 model without remote. it only goes up to 63 and my remote is broken so I need intructions on how to do it manually.
open mitsubishi front door see volumn control push button use +/- if you need new remote part no: Manufacturer Mitsubishi Part Number 290P123010 Description REMOTE
Dec 06, 2009 | Mitsubishi WD-65735 Television
Having trouble with tv volume when i push volume all the way up it says speaker off cannot find buttond to set speakers off and on
hi pavrj2003,
Have you put the switch into internal setting and tried? And, have you set the SAP off and switched the audio to stereo?
If you are sure the settings are correct and still no audio it may be a defective audio system internally. If so, it will require a tech to test it out. If the audio control system is not functioning properly (no mute and no volume indications) you may need an IC replacement. This could cost a fair amount; $150 or higher (plus the house call).
It is possible the audio went defective during the move. Sometimes a few whacks with the fist over a few places on the cabinet will wake up a bad connection or errant solder joint that was deactivated during transit.
Also, try the speaker switch again on the back panel; switch it a few times to burn through any corrosion that might have built up over the years.
best regards,
Jazerblue
Aug 25, 2009 | Mitsubishi WD-73733 73" HDTV
I cant turn the tv speakers on
You should be able to go to the main menu and select the setup menue, from there you should see the internal tv speaker option. Here isthe link to the manual: http://www.specsserver.com/CACHE/FRATSISBGCNF.PDF
May 20, 2009 | Mitsubishi WS-65819 TV
Television is on but no sound everything else is working
Usually when you see a symbol like that, the speakers have been disabled. Is there a menu option for turning off the internal speakers? This option is different than Mute.
Jan 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony VAIO VGN-CR23G Sound
i have sony vaio VGN-CR23G. i formatted this xp sp2now the sound driver is not installed on my machine. no audio output m getting........what to do..??
Sep 20, 2008 | Sony VAIO VGN-N130G/W Notebook
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
