Question about Compaq Presario CQ56-115DX Laptop
Laptop Manuals internal cd player is not working
  • sixpack6t9
    sixpack6t9 Mar 29, 2014
    Hi Helen Houliston, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
How do I burn a cd using a asus laptop with an internal cd port
Use Nero or Media Player for Mp3 or off Cd, or Easy Cd Creator.
Aug 28, 2017 | ASUS Computers & Internet
My dv 6500 pavillion hp laptop is not registering dvdr-cdrom in my computer but still spins when rebooting
The drive continues to spin every time you reboot the computer, that is normal.If the drive is not able to read any CD/DVD, it means, either the lens that reads the data has lost its life as the player is aged or the CD/DVD is not properly burnt.
If you encounter the same problem will all DVDs then definitely the DVD player lens is dead that it could not read CD/DVD anymore. Its time to replace the player if the spare is available or you can buy an External DVD player from staples or officemax or from any reputed stores.
My suggestion would be to go for external player, as we dont rely on players always.
Also external players are relatively cheap compared to that of internal spare of laptop.
Sep 12, 2012 | HP Computers & Internet
My CD Player for a [Compaq] Presario V3000 hasn't been working. It worked fine less than a year ago, then it stopped working. My Computer doesn't show the CD icon any longer, not even Device Manager seems...
It will cost about $30 to buy a brand-new CD/DVD reader/writer.
Any computer-store technician can easily "manually" open your current drive, and remove the CD/DVD media.
Dec 14, 2010 | Compaq (120192-B21) CD-ROM Drive
Hi, I have a dell XPS laptop and the cd got
When you get a cd stuck in your cd player there is a small pin hole near the push buttom in front stick a pin in it and it should release!
Dec 12, 2009 | Dell XPS M1330 Notebook
My cd player will not work but radio works fine
in the unit cd player and radio are two different things.so just check out with another cd first to confirm the fault.also if it shows "no cd error code" that means either the cd is faulty or the internal cd lens is faulty so its not reading the cd.but if its showing no such error and display is blank then,first try cleaning the cd tray with tissue paper and check if still the same problem its internal circuit error that needs to be checked with multimeter and repaired.mostly the repairing cost of circuit is minimum.
Aug 30, 2009 | Philips Car Audio & Video
Error on cd
Could be a number of things. Some of the older GM CD players don't work too well in very cold weather. Also, some of the older CD players won't play burned CD's. If it's not cold weather related, and you're using a regular production store-bought CD, then it is most likely an internal radio problem. Cheapest solution is to buy a cheap aftermarket player.
Mar 11, 2009 | 1999 Pontiac Sunfire
Do All DVD Players Also Play Music CD's
All DVD Players will read and play CD players
Nov 16, 2008 | Hitachi GD 7500 Internal DVD Drive
No sound
You might be missing the drivers for the sound card, try going to
www.cnet.com and then go to download
Look for a program call slimdriver.
Apr 13, 2017 | Dell (UJDCD450) External 4x CD-ROM Drive
Installing an internal dvd/cdwriter
Take apart computer
Look at the cable connecting the existing dvd/cdwriter in your computer, and follow the ribbon until you see a similar looking cable
Consult the PC manual to find out the # of pins you need to change and their position
Connect the new internal drive to the second ribbon
Reassemble your computer
Best to consult your product manuals for the PC, your BIOS, and the internal CD/dvd writer, and/or a techy-geeky friend.
Sep 04, 2008 | Televison & Video
Compaq Presario CQ56-115DX Laptop Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
