Question about Marantz Audio Players & Recorders
Marantz SR8500 "CHECK POWER5"
I was watching TV and the amp shut down. No power cuts or changes. Now I get "CHECK POWER5" have tried to unplug for a while with no luck. I have now unplugged everything from the amp and just have the power only plugged in ..... still "CHECK POWER5" Please ..... any suggestions?? Thanks in advance Grant
  • 3422 Answers
SOURCE: Plasma TV-power light does not come on
There are a couple of possibilities here. If the set is indead dead, the most likely culprit is the "standby" transformer. If you are getting a click followed shortly thereafter by another click, then the TV is detecting a problem and shutting down to prevent further damage.
And if you get no clicks or anything at all, I would suggest you to look at the fuse and the standby transformer. The standby transformer is a small transformer that supplies 5V to the system even when off to allow remote control. You need to see if the primary side of this transformer is open or not. You should have 5V.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 01, 2008
melnavz
  • 1226 Answers
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
Posted on Mar 03, 2008
SOURCE: Marantz SR8500
Check the settings on your dvd player!. It might be set to PCM
instead of HDMI.
Posted on Mar 10, 2008
  • 6 Answers
SOURCE: Marantz Sr8500
Check the speakers impedance. it should be greater then 6ohm otherwise you overload the system. Also, if the speaker sytem is rated (in Watts) below the amplifier's power it overloads the amp at higher volumes.
Posted on May 18, 2008
Sandy4u
  • 107 Answers
SOURCE: Turns on, then shuts down before anything shows on monitor
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Posted on Jun 14, 2008
Why marantz receiver 2328b sterophinc shut down?
Protective circuits have shut down unit to protect other wiring. Probably a power supply or out put amp issue.
Mar 09, 2015 | Marantz Audio Players & Recorders
MARANTZ SR8500 WILL NOT POWER UP
The audio output stage has a load causing the auto protect to kick in. First check speaker wires for shorts, if okay it is the above mentioned.
Apr 08, 2012 | Marantz SR8500 Receiver
Hi, I have recently purchased an SR7005 which is connected to an HD PVR via Audioquest Cinammon HDMI cable. While watching programs, I lose audio immediately after an advertisement break. If I pause...
If you are watching adverts that implies a broadcast TV sound signal. What happens is that the broadcaster will switch off sound especially Dolby signals during add breaks. Therefore it could be your TV that stops sending the sound to the Marantz. So check the sound settings of you TV. It might have an auto feature that detects the signals, that could be switched to manual or just a wrong sound signal that causes the problem.
Jun 12, 2017 | Marantz SR7005 Receiver
Hi Strange problem with Marantz pm7001 When ever I turn the volume upto around 1/3 and 1/2 of the way, the amp cuts out and reset it self down to minimum volume. It seems like the amp ins't enough power...
What's probably happening is that the amplifier is shutting down or cutting back the volume as protection from damage. You may have a partial short in the speaker wiring that is not a problem at lower levels, but at higher ones causes the amp to see too low a load. There may a problem with a speaker or crossover component that is breaking down at higher volumes. Or something in the amp's output stage is unable to handle the load.
Test the system with a known good speaker system and length of wire and see if the trouble continues. If it does, you'll know it's the amplifier that needs to be checked. If the test speakers can reach normal volume, you can start checking the wiring and other speakers for the source of the trouble.
Mar 13, 2011 | Marantz Audio Players & Recorders
I'm getting a "Check Power
has the power whent out at home if so you my have to unplugg it for aboult 30sec then plugg it back in that sould take care of it
Jan 03, 2011 | Marantz SR8500 Receiver
Amplifier power cutting out
not enough power to amp and or amps location is too hot might want to invest in a couple cooling fans from computer store and attach where needed
an amp should take up to 3/4 load but when not enough air to it to cool it off it will shut down
try this turn gain all the way down and slowly work up too desired amp volume setting
May 07, 2008 | Audio Players & Recorders
Marantz Sr8500
Apr 12, 2008 | Marantz SR8500 Receiver
Marantz SR8500
instead of HDMI.
Jan 27, 2008 | Marantz SR8500 Receiver
PICTURE ON TV
DVD should be connected to an input on your tv not the monitor out.
Dec 01, 2006 | Marantz SR8500 Receiver
53 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
